Topic: Potential converter problem Posted: 21 Aug 2018 at 8:55am |
Not sure about that, mine in bulk is over 14 volts. Float 13.1 and absorbtion is 13.6. The charging cycle is defined by battery charge status. I have never seen mine in bulk. I have a volt gauge and monitor 12V status. Mine cycles in 2 phases, which is normal for a properly charged and used battery.
mrm435075
Posted: 21 Aug 2018 at 8:49am |
Actually the charger should go through a charging cycle when it is turned on. A charging cycle is Bulk, Absorption, then Float. Float mode indicates fully charged batteries. In absorption the charging voltage applied by the charger will be somewhere over 14.1 volts.
Michael
2019 R-Pod 179 HRE Cocoon
2011 Tacoma TRD 4 door
DavMar
Posted: 18 Aug 2018 at 5:39pm |
Originally posted by Tibof
Even the small sample that shows up in this forum (which is actually empirical data) is sufficient mathematically to verify a wide range of failures.
+1 Exactly, well stated.
Obvious things that are killers to electronics circuits are water, heat, and vibration. We can eliminate water to this which leave's only heat and vibration. I don't think WFCO problem is heat since they use a computer fan plus large ceramic power resistors that can dissipate a large amount of heat. So that leaves only vibration and I was shocked to find when my converter died only a little dab of caulk cementing these resistors to the circuit board that had broken loose. If you want to insure that your WFCO converter will not have the same problem the solution is simple. Buy a tube of silicon adhesive and put a generous amount of this around these resistors and the circuit board. These resistors are pretty obvious in that they are large white square ceramic components (two in the front and one toward the rear of the board if I remember right) and don't worry how much silicon you use to anchor them to the circuit board since its non-conductive.
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
Tibof
Posted: 18 Aug 2018 at 4:38pm |
How many converters have failed? How many have been installed? I would be interessted in the numbers you have to prove your case. in Tibof's case the converter was way out of warranty.
The WFCO converter has a two year warranty. We can debate the meaning of "way out" but given the age of the Pod in question, we are looking at 3 years at most on this one, ie. a year beyond the deadline. I was told by WFCO that they can go beyond the two years, but they wouldn't define what that meant. But, OK, lets accept the strict deadline of the warranty. As you may know from my spoiler issue, if it is a product defect (as with the spoiler), my view is that a good company stands behind the product rather than blame the problem on the owner or some unseen force. In another conversation with WFCO, I was told that the problem was probably due to a thin or cold solder joint. That's a product defect. Given the minimal cost WFCO has in one of those foreign made converters, they could easily meet the consumer of a bad product half way (and still make money and a strong reputation that's worth money). Prove the case? Even the small sample that shows up in this forum (which is actually empirical data) is sufficient mathematically to verify a wide range of failures.
2015 Pod Hood River Edition
2012 Tacoma Crew Cab 4 Liter
lgblau
Posted: 18 Aug 2018 at 3:55pm |
Hi GlueGuy....Is there a schematic with the parts you mentioned. I am electrically challenged and will not be able to find them. Thx
Leonard🌵
2017/179
2017 Ram 1500
Posted: 18 Aug 2018 at 3:52pm |
Me either, but agree with you. Lot of experienced folks on this board. Justified in having an educated opinion. Personally I have had no issues with my WFCO convertor, when I do. I'll fix it. When that happens, I'll probably have an opinion.:)
Posted: 18 Aug 2018 at 3:21pm |
I have not looked at this power resistor on our WFCO converter, but if it is getting hot, it may be undersized or need a heat sink attached. I've worked in the computer/electronics industry for over 40 years, and have seen lots of power resistors get too hot and then work themselves loose.
DavMar
Posted: 18 Aug 2018 at 10:33am |
Inother words you don't have data. You have an opinion.
Let see I think you can count as well as I can, yes? When numerous forum user post they have a problem then I think that gives you a good indication there is a problem. Yes, I do have a OPINION, indeed, its an opinion from spending over thirty years repairing electronic circuits that are used in a high vibration environment. Which I believe may give me some validity to make an opinion but I guess you believe otherwise? So please tell me and everyone else what your opinion is and your qualifications to come to such a conclusion.
Peace
wonder dog.
2017 Rpod 180
Lexington, NC
Posted: 18 Aug 2018 at 10:23am |
2011 R-Pod 177
2010 Ford F-150
DavMar
Posted: 18 Aug 2018 at 10:07am |
I believe if count up the number of people who have posted on this forum on the failures of WFCO converters it is more then obvious this company now has a problem. One that could easily be solved by a more generous use of silicon caulk to anchor the ceramic power resistors to the circuit board which would prevent their leads breaking off from vibration. I spent my career working on electronics in a very heavy vibration environment so not to brag but I think I'm a bit qualified to make a diagnosis and judgement. No matter who manufactures a converter or how long you have had it there is no excuse for this type of fault, period! Tibof has a valid complaint whether or not his converter was in or not in the warranty period. We all may agree to disagree here on this or other issues concerning our R-Pods that part of what an open forum is all about. In the end it's about helping each other out with what ever problems we encounter on out campers I would hope everyone would agree with? One can only hope some one from Forest River is also viewing these posts and comes to the conclusion they have a problem they need to address.
wonder dog.
2017 Rpod 180
Lexington, NC
