Page 12> |
Topic: Confused at Battery Shut Off SwitchPosted: 21 Jul 2018 at 10:41pm |
This is the type I purchased from Amazon.It has been very reliable and since it is a marine model, it is suitable for a moist environment.
SteveA
Joined: 19 Jul 2017 Location: Sandpoint Id Online Status: Offline Posts: 56 |
Posted: 21 Jul 2018 at 2:34pm |
This is the unit I purchased from Amazon. Blue Sea Systems 300 Amp m-Series Battery Switches |
2017 179 1/2
jimandclare
Joined: 13 Apr 2016 Location: Erie, MI Online Status: Offline Posts: 96 |
Posted: 21 Jul 2018 at 2:27pm |
Jim & Clare
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2735 |
Posted: 21 Jul 2018 at 2:23pm |
ChuckH
Joined: 26 Jun 2018 Location: Houston, TX Online Status: Offline Posts: 3 |
Posted: 21 Jul 2018 at 11:41am |
Would someone post a picture or link where to buy a battery shut off switch? My wife and I just bought our R-pod last month and still learning a lot about it. Thanks for all your help.
clickscrazy
Joined: 09 Aug 2017 Location: FL Online Status: Offline Posts: 106 |
Posted: 16 Jul 2018 at 5:03pm |
Cool. Yeah, I plan on keeping the battery switch on, was just curious.
2018 R-Pod 171
2014 VW Touareg TDI |
Posted: 16 Jul 2018 at 3:43pm |
If you do that, the converter won't be able to maintain your battery. The converter will supply 12V power to the 'Pod, but some have found having the battery connected provides a more consistent power. I remember reading one person who was running with the battery disconnected and found the furnace was not running right. Having the battery in evens out any power fluctuations.
clickscrazy
Posted: 16 Jul 2018 at 7:47am |
Hi All. I installed the cut off switch. I did what I think is a pretty seamless integration.
Mounted to the top of the box, the posts cleared. Black silicon around the switch to form a watertight seal (as long as that will last, probably 1 season). Screwed the switch on. Used a 19" 6 Gauge wire from Walmart. Glad I went a bit longer than the 12" one I started with. Question: Is it bad if I accidentally turn the battery off WHILE I am plugged into shore power?
2018 R-Pod 171
Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1455 |
Posted: 15 Jul 2018 at 1:06pm |
Battery posts are different sizes. I forget which is bigger, but you may have a wire with a fitting for the other post. TT
FJ Cruiser |
clickscrazy
Posted: 15 Jul 2018 at 9:49am |
Easy solution. Put it on the negative side!
My 4 Guauge does fit, it is just doesn't hug the post as much as I would like. Maybe I will still use it.
2018 R-Pod 171
Page 12> |
