  New Posts New Posts RSS Feed: gas grill outlet on a 179
Topic Closedgas grill outlet on a 179
OldNeumanntapr View Drop Down
Direct Link To This Post Topic: gas grill outlet on a 179
    Posted: 26 Jun 2018 at 9:32pm
I wanted to use the quick disconnect on my new RP 180, but after reading the posts it seems like I would have to use a BBQ without a regulator. My little portable Weber grill has a regulator built in, so I would have to either modify it or buy a new grill. So from what I gather from this thread that running two regulators in line would drastically reduce the flame? Is that correct?
I have a 5 gallon BBQ tank but my wife is adamant on not bringing it for traveling because of the extra weight and (she claims) the danger of a five gallon propane tank in the shell of the truck.
I guess the small disposable bottles would work better for a two week trip.
Tom A View Drop Down
Direct Link To This Post Posted: 27 Jun 2018 at 6:15am
Now the question is: Where do I get a hose with the quick connect fitting on one end and the grill connection on the other?
I called five local RV dealers and none of them have it.
2018 Sequoia--2018 RP 190
Direct Link To This Post Posted: 27 Jun 2018 at 7:25am
OldNeumanntapr,
You are correct, it is a low pressure line, can't have 2 regulators.
Direct Link To This Post Posted: 27 Jun 2018 at 7:26am
Tom A,
Coleman makes a hose specifically for their products, Camping World has it. Weber does also.
Direct Link To This Post Posted: 27 Jun 2018 at 7:45am
You can also Google "convert Coleman to low pressure" and watch a dozen youtube videos of changing over, most with parts lists, or kit links.. I converted our "fold and go", just because I could, and bought the "kit" for our Blackstone.
Direct Link To This Post Posted: 29 Jun 2018 at 7:36am
Has anybody ever seen a gas stove without a regulator?  I have a 2 burner PRIMUS and unless they make a small regulator that is in line at the connection, it doesn't have one.  At least it doesn't have one like I'm used to seeing.
Direct Link To This Post Posted: 29 Jun 2018 at 8:13am
Yes, CAMCO makes one, it's the Olympian 5500 Stainless steel. Comes with a mounting bracket, connect hose for low pressure and a storage bag. Available on Amazon for around 180.
Larry-D View Drop Down
Direct Link To This Post Posted: 29 Jun 2018 at 8:20am
This is the one we have.
https://www.ebay.com/itm/RV-Mounted-BBQ-Motorhome-Gas-Grill-BBQ-Trailer-Side-Mount-Barbeque-Grill-NEW-/121166076296?hash=item1c360f9988
With this hose.
http://www.ebay.com/itm/Outdoor-Camper-RV-Kitchen-10-Propane-Brass-Quick-Connect-Hose-Stove-Grill-Fit-/202346921547?hash=item2f1cd0fe4b
