Page 12> |
Madeshotels
Joined: 23 Jun 2018 Location: Lafayette, la Online Status: Offline Posts: 1 |
Topic: Slide out coverPosted: 23 Jun 2018 at 3:52pm |
Hi, I purchased a 2010 Rpod M175 and I would like to put a cover over the slide out. Has anyone done this and if so which did you purchase. I did find a cover but it’s one you have to install after u open. I would like the type that opens with the slide out.
Posted: 23 Jun 2018 at 3:55pm |
etrailer.com sells them now for around 200, free shipping.
Posted: 23 Jun 2018 at 4:38pm |
But what size is that? When I look at one sized for the 179, it usually runs significantly higher than $200.
Posted: 23 Jun 2018 at 5:07pm |
Not sure SH, I looked those that supposedly f0r 178, believe they were 190 plus, all depends on width, what is dimension needed for a 179? 10 footers were significant different, no way you need a 10 footer.
Posted: 23 Jun 2018 at 8:06pm |
The slide-out on the 179 measures 109-1/2" flange edge to flange edge, a smidge more if the corner covers are counted, or about 110" That means I would need either a 9' or 9.5' awning, which are currently listed on eTrailer for $349.95.
Posted: 24 Jun 2018 at 7:24am |
Thanks SH for taking time to respond, obviously I had no idea how wide a 179 slide is. The OP will have to measure the 175 slide and use that as guide. As I recall the 175 has a 55" sofa in the slide.
TheBum
Posted: 25 Jun 2018 at 11:46am |
We got this one from this seller for our 179: http://www.rvpartscountry.com/RV-Slideout-Cover-Roller-98-105-White.html You have to buy the brackets separately, which adds another $70. When we bought ours over a year ago, it came with the brackets, but apparently no more. |
Alan
Posted: 25 Jun 2018 at 12:13pm |
How does it mount? Does it attach to the flange or to the wall below the flange?
TheBum
Posted: 25 Jun 2018 at 1:36pm |
Wall below the flange.
I don't remember if I needed the long or short brackets because I don't remember the flange height; I followed the recommendations on Carefree's website:
It's a pretty quick install. The screws for the brackets are all self-drilling. The hardest and most time-consuming part was feeding the fabric into the keder rail: I spread the ends of the rail a little to help prevent snagging. |
Alan
Posted: 25 Jun 2018 at 2:34pm |
The slide cover from etrailer doesn't use the keder rail. The brackets are universal. I bought one for my 178, it was 195 bucks complete. The larger 179 cover is indeed more expensive.
Page 12> |
