Tom A
Topic: Suggest aGood Propane Grill Posted: 16 Jun 2018 at 4:29pm |
Were looking for a portable propane grill to use with the outlet port on our 190.
Any suggestions?
2018 Sequoia--2018 RP 190
Posted: 16 Jun 2018 at 5:08pm |
Diehard Weber Q person, now the 17" Blackstone. Can do it all. Everything is adaptable.
Billy Bob
Posted: 17 Jun 2018 at 8:33am |
I'm a Traeger fan. Needs 110 volts but can use an inverter also. Only uses power to run the auger. I have the new Ranger which is a tabletop. Also have a tailgater model available.
2019 RPOD 190
2017 Chev Colorado 4 X 4
Yellow Lab and English Springer Spaniel
Posted: 17 Jun 2018 at 3:07pm |
Step away from the gas brother.. 12v and a bag of your favorite pellets and the Green Mountain Grills Davy Crockett will make you a super star camping chef.. 150F to 550F.. smoke, bake, or grill..
mjlrpod
Posted: 17 Jun 2018 at 3:21pm |
I use a webber Q , and a 17 inch blackstone. I suppose you could buy the grill top option on the blackstone if you wanted to do a 2 for 1, but I already had the Q.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Posted: 17 Jun 2018 at 4:25pm |
Originally posted by mjlrpod
I use a webber Q , and a 17 inch blackstone. I suppose you could buy the grill top option on the blackstone if you wanted to do a 2 for 1, but I already had the Q. |
For our home, we have a Weber Genesis; a great grill, we just love it. The main feature I've come to appreciate is that it's made of real stainless steel AND there are easily available replacement parts.
That gives me a built-in bias toward Weber grills of any kind. Any idea what a Weber Q is made of? There's absolutely nothing on the Weber web page.
Posted: 17 Jun 2018 at 4:40pm |
The Weber Qs.
The lid and cook box are made of cast aluminum.
The cooking grates are cast iron, porcelain enameled.
The burner is stainless.
I had a Weber Q for 13 years, best grill I ever owned.
Tom A
Posted: 17 Jun 2018 at 5:04pm |
Well thanks everyone. I've decided to stick with my little portable rectangular Weber charcoal grill for now. Then I can use the charcoal to start the campfire.
That pellet Davey Crocket looks like an awesome grill, but a lot to haul around in a Pod.
I have the Genesis for home use, but ever since I got a Traeger, the Genesis is gathering dust.
Thanks again.
Tom A
Posted: 18 Jun 2018 at 9:59am |
Disregard the above post--- upon further consideration of carry a bag of charcoal and a grill, I took some advice from a few here and bought a Weber Q1200.
Now the question is, do you run it off a separate propane tank, or with a hose from a quick connect fitting on the camper?
Larry-D
Posted: 18 Jun 2018 at 1:38pm |
If is has a pressure regulator then to run it off the quick connect fitting you have to remove the regulator because the propane at the quick connector is already regulated at the pod's propane tank connector hose.
if the grill doesn't have a regulator then it'll work with the quick connect, just need the hose.
