  New Posts New Posts RSS Feed: What is this propane part called
Topic ClosedWhat is this propane part called
MadCity View Drop Down
Direct Link To This Post Topic: What is this propane part called
    Posted: 10 Jun 2018 at 2:25pm
What is this piece called? The "aluminum block" with 2 bolts attaching it to the trailer and two hoses and a quick-connect attached to it? This one is in the front of the trailer. I have one in the back left with an extra connection that I plan to add another hose and extend it to the opposite side of the trailer. From there I need the additional "block" (whatever it is called) to attach to the trailer so I can add the extension hose (from the back left "block") and another quick-connect.
I've tried searching the net in vain. It's hard to search when you don't know what to call the thing.
Thanks!
2018 R-Pod 176T
2008 Honda Pilot AWD
Direct Link To This Post Posted: 10 Jun 2018 at 2:47pm
My pod is too old and doesn't have this but from your pic it appears to be a quick attachment for a gas/propane grill.  The threaded hose that is attached to the aluminum block, trace that line back to the source; probably ends at the propane tank.
Direct Link To This Post Posted: 10 Jun 2018 at 2:53pm
Hi Jato,
Thank you for the quick response. I tried to explain the piece I was referring to, but it's difficult in words.  The piece is not the quick-connect, it's the "blocky" part that everything attaches to (including the quick-connect and hoses). It's the "aluminum block" piece that I am trying to identify. It has 2 bolts holding it on to the RV frame and 3 openings. One the quick-connect goes into, and the other 2 the hoses attach to. I hope this helps to further clarify. It must have a special name, because when I search for propane parts I can't find it.
2018 R-Pod 176T
mjlrpod View Drop Down
Direct Link To This Post Posted: 10 Jun 2018 at 3:11pm
Normally that would be called a manifold.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 10 Jun 2018 at 7:31pm
Sorry Madcity. I didn't read your question correctly.  However mjlrpod has correctly identified the part.
wthoms2000 View Drop Down
Direct Link To This Post Posted: 13 Jun 2018 at 12:12am
This is known as a tee in plumbing, along with street elbows and plugs and caps. Was not able to find this mountable alum tee, but found a brass tee:
https://www.campingworld.com/propane-adapter-tee
Good luck!
Porta Poddy
Wil and Luz, Orange County, CA
2017.5 179 HRE
2021 Ranger XLT FX4
REDARC Brake Controller
