Iceworm
Topic: Trailer Brake Issue Posted: 29 May 2018 at 9:18pm |
Was the controller the problem. I had a situation as you described and after checking voltages, tensioners at brake etc. Noticed a wire broke off of the crimped connector just a few inches outside of the brake housing. Fixed with butt splice connector and full brakes again. About a week later same thing happened to the second wire. Just got back from trip from Penna. to Alaska. I will cut the factory splices off the other brake and replace with butt splices sealed with silicone soon.
Posted: 28 May 2018 at 4:27pm |
Well that would be good if the OP had a Ford. He doesn't he has a Chevy, God Bless you Ford owners , huh?
Posted: 28 May 2018 at 4:26pm |
Posted: 28 May 2018 at 12:37pm |
our dealer installed a Teconsha brake controller as part of our "package". When they described it as "plug and play", I thought they meant it was integrated with the truck's electronics. What they actually meant was that it plugged directly into the pre-existing connector for the OEM controller.
They also didn't mention that it had to be mounted under the dash, and that it would be bumping my right knee all the time. I didn't like that.
So I un-installed the Teconsha, and installed the Ford OEM controller, which fits into a pre-existing slot in the lower part of the dashboard. Big plus is that it completely integrates with the truck electronics, and provides proportional braking automatically. It also doesn't bang my knee all the time. I like that.
DavMar
Posted: 28 May 2018 at 10:53am |
+1 to mcarter suggestion. If you TV doesn't have the wiring for plug and play with your break control already installed. You should be able to buy the wiring that plugs into your vehicle wiring harness and then into your controller. I had to do just that with my Tacoma it had the plug in the harness but I had to just buy the wiring that plug into that and then into my Tekinsha P3, no biggy to deal with.
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
Posted: 28 May 2018 at 9:14am |
Personally I would go with a new controller and the right plug and play cable. Most newer vehicles have the wiring installed to add the brake controller, Ford and Chevy certainly do. I tow with a Silverado and I bought a Tekonsha P3 with the cable that plugs into my interface panel, no tapped wires and a secure fit all around.
john in idaho
Posted: 28 May 2018 at 8:59am |
Maybe you need to start over with a new controller? Taped wires are a bad sign. Did you check that the trailer plug and truck socket is clean? That electronics cleaner in a spray can works well.
GlibGuy
Posted: 28 May 2018 at 8:42am |
Originally posted by GlibGuy
I didn't see any numbers; removed it from it's bracket under the dash and found "14217+" on the rear of the controller. Comes up "item not found" when I put that in the search box (with and without the +). The number is sort of stamped on the rear.
And when you refer to being "seated completely to the receiver" do you mean the 7 point trailer plug? |
Sorry for responding to my own post, but I decided to google Quest brake controller 14217+ and it comes up Husky 31899 which looks EXACTLY like mine except I don't have the flat connector! And here may be the problem; my wires are taped together.
I'm going to pursue this unless someone has other thoughts.
MICK
Posted: 28 May 2018 at 8:38am |
You may want to call Husky. I'm sure they'd be happy to help you figure out which manual applies to your model.
GlibGuy
Posted: 28 May 2018 at 8:34am |
MICK
