  New Posts New Posts RSS Feed: sewer
Topic Closedsewer
Tars Tarkas View Drop Down
Direct Link To This Post Topic: sewer
    Posted: 21 May 2018 at 6:04pm
Originally posted by grizwalsh
Just went on our first shakedown cruise and I have a few questions for you veterans--We have a sewer hook-up and I just want to know how it diverts from the holding tank--is there a valve you switch?
I'm not sure I understand what you're asking so I'll give a long explanation.  There are two holding tanks on pods for waste; a black water tank (for the toilet) and a grey water tank for the sink and shower.  Each tank has it's own outlet on the street side of the pod, probably fore and aft of the axle.  Take the cap off, one at a time, black tank first, hook up your sewer hose, put the other end in the receptacle for the waste, pull the T-handle out and the sewage will come gushing out.  When everything is out of the black tank, close the valve, take the hose off and put the cap back on.  Move to the grey tank outlet and repeat.  Rinse your hose and any mess you may have made at the dump station.
TheBum View Drop Down
Direct Link To This Post Posted: 21 May 2018 at 12:59pm
When you look under the Pod, you should see the dump valve with a large handle protruding to the side. Simply pull out on that handle to initiate the flow out of the holding tank and into the sewer. Push it back in when done.
As for the radio, take a look at the inside wall plate where the TV cable connectors are. You should see a little button on it. If the LED indicator next to it is off, then press the button to turn it on. This activates the signal booster.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
grizwalsh View Drop Down
Direct Link To This Post Posted: 21 May 2018 at 11:40am
Just went on our first shakedown cruise and I have a few questions for you veterans--We have a sewer hook-up and I just want to know how it diverts from the holding tank--is there a valve you switch?---also we don't get very good reception from our radio--anyone else have that problem--Thanks
grizwalsh
