  New Posts New Posts RSS Feed: Bauer Lock
Topic ClosedBauer Lock
TheBum View Drop Down
Direct Link To This Post Topic: Bauer Lock
    Posted: 14 May 2018 at 3:00pm
Originally posted by Tom A
Originally posted by TheBum
I can't speak for that brand of lock, but we bought an RV Locks keyless lock and it was a perfect fit.
Do you have a link to that "keyless lock"?
We have this one:
https://www.rvlock.com/collections/all/products/rvlock-v4-0-w-integrated-keypad-for-rvs
This one is more compact and less expensive; it wasn't available when we bought ours:
https://www.rvlock.com/collections/all/products/rvlock-v4mini-right-hand-w-integrated-keypad-for-rvs
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Direct Link To This Post Posted: 12 May 2018 at 11:38am
One additional thing to check are your batteries.  My lock did the exact same thing as yours, checked my 4 batteries and one was low in power, enough to cause the scenerio you described above.  Changed all 4 out and worked perfect after that.
Tom A View Drop Down
Direct Link To This Post Posted: 11 May 2018 at 9:06pm
2018 Sequoia--2018 RP 190
Direct Link To This Post Posted: 07 May 2018 at 3:26pm
Alan
Three cats
voisj View Drop Down
Direct Link To This Post Posted: 07 May 2018 at 3:09pm
I also had this problem on both my iPod and my RV and I just took a file and had to file down the strike hole a little bit until it worked perfect.
SLOPODMODS
John&Sue,SLO,CA
texman View Drop Down
Direct Link To This Post Posted: 07 May 2018 at 10:34am
so just an alignment problem then sounds like.  thanks!  i will give it a try.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 07 May 2018 at 9:13am
Loosen the mounting screws a little bit, use the key to extend the deadbolt, check for clearance, then tighten the mounting bolts again.
Direct Link To This Post Posted: 07 May 2018 at 8:50am
I have the bauer lock on my rp182g that came with the pod.  After spending way too much time messing with this thing, the best i get is locked out of the pod, literally.  it will engage and lock and give me a long beep which means that it did not fully extend, but enough extension to lock me out.  Since it did not fully extend, then it is unable to retract and you are locked out and must use the key to unlock. This is the first time i have tried to use it since buying the pod new in 2015. i am wondering if i need to drill the door jam to allow clearance for the bolt to fully extend?  has anyone else dealt with a lock like this as i don't know if they are standard on the pods or not. Confused it looks like this:
TexMan 2015 182g
2018 Sequoia
TexManMods
