lgblau
Joined: 09 Feb 2018 Location: Arizona Online Status: Offline Posts: 140 |
Topic: 179 slide motor locationPosted: 05 May 2018 at 11:09am |
Okay, I give up. Where is the slide motor in my 179. Thanks.
Leonard🌵
2017/179 2017 Ram 1500 |
Posted: 05 May 2018 at 11:11am |
There are two slide motors. You will need to fold back the rubber seal just above the top track on either side of the slide out to get to the motors.
lgblau
Posted: 05 May 2018 at 11:20am |
Thanks StephanH, but I do not see anything like you described.
Leonard🌵
lgblau
Posted: 05 May 2018 at 11:52am |
Thanks again StephenH. I found the motors. You were right on
Leonard🌵
Posted: 05 May 2018 at 8:56pm |
You're welcome. They are hard to see. That's for sure.
lgblau
Posted: 05 May 2018 at 9:45pm |
Mine has a controller under the fridge with instructions on what to fo if the slide fails. To bad the factory installed it upsidedown, and at the very bottom. Hard to read and hard to follow the directions. At least I now know more thsn I did this AM.
Leonard🌵
Posted: 06 May 2018 at 7:37am |
The controller for mine is in the same place. I don't know if it is upside-down though as I haven't looked at it. I'll wait to do so because that panel below the refrigerator has been a problem and I now have it anchored pretty well so I don't want to take it loose to look.
lgblau
Posted: 06 May 2018 at 10:45am |
Yeah, mine did not go back on well. Giant wood screws thru metal frame equals one time use. At least I now know what is down there.
Leonard🌵
