  New Posts New Posts RSS Feed: 2015 R-179 wiring schematic
Topic Closed2015 R-179 wiring schematic
RoadToad View Drop Down
Direct Link To This Post Topic: 2015 R-179 wiring schematic
    Posted: 21 Apr 2018 at 11:19am
Hello
   Down in Texas working on our second hand
 2015 R-179.  Need a wiring schematic- could not find one with paperwork. Right now it's wiring for running lights-signal lights & brakes.  perhaps there's a sight online?  RoadToad in Toadj Me-Haul
2015 RP179
CharlieM View Drop Down
Direct Link To This Post Posted: 21 Apr 2018 at 11:25am
No such thing available. FR's motto: Let no two Pods be built the same.
Direct Link To This Post Posted: 21 Apr 2018 at 11:34am
All the running lights, signal lights, & electric brakes you mentioned should go directly to the 7-pin Bargman connector at the tongue. You probably don't need a wiring diagram so much as tracing the wires from the Bargman to the various end-points.
Direct Link To This Post Posted: 21 Apr 2018 at 3:57pm
Pods are pretty standard to the RV standard.   I'm not saying they can't be different, if somebody jacked with it. Starting at the Bargman - Looking at the 7 pin trailer plug - At 1 o'clock is the trailer tail and running lights - it is GREEN. At 3 o'clock is the left turn and stop, it is RED. At 5 O'clock is the ground which is WHITE. At 7 o'clock is the brake controller which is PURPLE. At 9 o'clock is the right turn and stop which is BROWN. At 11 o'clock is 12 volt power which is BLACK. The center is the reverse lights which is YELLOW. Pretty common info and like I said a RV standard. etrailer.com has an extensive wiring info page.
Direct Link To This Post Posted: 21 Apr 2018 at 6:18pm
I get a lot of info from the etrailer on youtube. Really helpful!
Previously owner
