  New Posts New Posts RSS Feed: Anti sway
Topic ClosedAnti sway
Direct Link To This Post Topic: Anti sway
    Posted: 14 Apr 2018 at 7:01pm
Believe I found the one you folks are speaking of:
If so, please let me know. I'll order today.
Yep. That's the round bar version. It's a tad less expensive than the trunnion model.
Olddawgsrule View Drop Down
Direct Link To This Post Posted: 16 Apr 2018 at 4:52pm
It's on it's way here and will be mounted. Today driving home in my F150 I crossed through same area and saw the trees swaying. It shifted 'my' truck.
Ya, I think I'm going to be happy adding this to the rig setup!
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
TheBum View Drop Down
Direct Link To This Post Posted: 16 Apr 2018 at 5:19pm
Do you have a torque wrench capable of at least 250 ft-lbs? You'll need to either buy, rent, or borrow one. I used a "cheap" 300 ft-lb one I got from Harbor Freight for $70 or so.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Direct Link To This Post Posted: 16 Apr 2018 at 8:23pm
Yeah. That 250 ft-lbs can be a challenge. We had a neighbor once upon a time who had a big class A motor home. IIRC, he needed to do something like 250 ft-lbs of torque on the lug nuts (I may be off a bit on the exact torque; it was ~~ 25 years ago). What he did was calculate the length of a breaker-bar he would need if he stood on a lever (weight X moment arm). He marked his torque with a magic marker on the breaker bar, and bada bing. The only hassle is figuring out how to maintain your balance with one foot on the breaker bar, and that he had to try to keep it horizontal for the final torque.
Direct Link To This Post Posted: 17 Apr 2018 at 11:10am
I had to really put my weight into it. (Un)fortunately, I have plenty of weight to spare. The important thing is that the bolts are torqued enough for the conical washers to go completely flat.
Alan
Three cats
Direct Link To This Post Posted: 17 Apr 2018 at 4:19pm
Good info guys! Thank you!
Byways no Highways
2017 Tacoma
Truck Camper Build
Direct Link To This Post Posted: 18 Apr 2018 at 1:11pm
Found a friend with a torque wrench. You folks have any clues what size sockets I need for it?
Especially metric..
Byways no Highways
2017 Tacoma
Truck Camper Build
Direct Link To This Post Posted: 18 Apr 2018 at 1:20pm
Instructions say 1 1/8, 1 1/16, 3/4 and 1 7/8 for the ball. Sounds good to me...
Anything else you found useful, please add.
Byways no Highways
2017 Tacoma
Truck Camper Build
Direct Link To This Post Posted: 18 Apr 2018 at 4:30pm
I was thinking they were all SAE sizes.
Something I found really helpful was a very large crescent wrench (24") to provide resistance against the nut turning as I was using the torque wrench on the bolt. I attached the crescent wrench to the nut such that the handle would press into the ground and provide that resistance.
Alan
Three cats
Direct Link To This Post Posted: 22 Apr 2018 at 7:28am
The E2 is on the truck! Took about 2 1/2hrs, not bad..
I swear 45 minutes of it was reading the instructions and trying to figure out where this one piece went. LOL
3 attempts at adjustment to get it in the 'Honey' spot.
Winds were fairly strong driving to the shop to do this. Winds picked up for the drive back. With greater winds I felt much less sway on the way home. I'm liking!
I 'mocked' having the truck and trailer loaded with bags of pellets so I'd be pretty close to what and how we'll load.
Side note: I also had my LED battery voltage gauge (not my new voltage/wattage gauge) wired in to see if the truck was charging the batteries. All good there as well!
Byways no Highways
2017 Tacoma
Truck Camper Build
