Page <123> |
XDigger15
Joined: 23 Mar 2018 Location: South Carolina Online Status: Offline Posts: 13 |
Topic: Please help Newbie with Fuse PanelPosted: 25 Mar 2018 at 4:25pm |
Will do!
XDigger
2010 RPod 173 2000 Chevy 1500 V8 |
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2735 |
Posted: 25 Mar 2018 at 4:55pm |
Then go through the procedure step-by-step. It's all relatively simple with a few basic pointers, but would be difficult for us to explain to you over the net. In the mean time, we are all rooting for you. Good luck. |
XDigger15
Posted: 25 Mar 2018 at 6:43pm |
I'll be gettin to it, fellow podders. Thank you for the encouragement!
XDigger
Posted: 25 Mar 2018 at 9:24pm |
Here is link to WFCO Troubleshooting guides, determine what type you have then follow the chart very easy.
http://wfcoelectronics.com/trouble-shooting-charts/ |
Posted: 26 Mar 2018 at 7:12am |
I apologize for not reading the whole thread, but this issue.. Did you move the breaker reset all the way to the LEFT before clicking it back to the RIGHT? It has to be "reset" by moving it physically to the left. If you try to flip it back on without doing that, it won't. If the breaker IS bad, the "fix" is to go buy a compatible breaker, and replace it. 2 screws/wires. Turn off the shore power first. |
XDigger15
Posted: 26 Mar 2018 at 8:37am |
Good Morning, furpod! Thanks for chiming in! I did move the circuit breaker all the way to the left, and then back to the right, and it is definitely not working. I've never replaced one before, but the Panel box is easily accessible, and I am pretty good with tools. Maybe I'll give replacing it a try. From all that I've read on the web (lots), it sounds like lots of Pod Owners have had problems with the "converters/inverters" going bad. I don't want to go to the trouble just to have it go bad the next time I go camping, though. Have you had any trouble with yours?I also wonder why the Furnace Fuse (7.5A) was in the wrong place, and if that had anything to do with it. All of this happened the first weekend of March, which was also the first weekend I ever used my Furnace.**I have only had the POD since Feb 5... ![]() |
XDigger
Posted: 26 Mar 2018 at 9:13am |
I very much doubt that the fuse (12V circuit) had anything to do with the breaker going bad. I did have a converter go bad on me. I ordered a replacement on Amazon and installed it myself. After we got home, I got an RGA number and sent the bad one in and it was replaced under warranty. Now I have a spare just in case it happens again.
My understanding is that the converters are generally reliable, but that WFCO got a bad batch from the manufacturing plant. These are the ones having problems. If, after you fix the breaker problem, the converter tests bad and your converter is still under warranty, contact WFCO and get it replaced. See the WFCO Warranty Returns web page for details. |
XDigger15
Posted: 27 Mar 2018 at 10:19am |
Thank you, StephenH.
I have an appointment to take the R Pod back to the dealer I bought it from next week. I have had a few issues, and this issue has just really blown my mind. I was wrong about the Fuses being put in incorrectly. I went back and checked, and they had been right, so I moved them back.The dealer I bought it from is not an R Pod dealer. Should they be responsible for knowing about, testing all the components sufficiently, and being sure that I knew what I was doing, BEFORE I left the dealership?? It may have been the use of the furnace that caused the problem. I have no idea. I'm just afraid to start replacing things, or spending more money on things that I feel may be the responsibility of the dealership. I had only had the camper 1 month when all of this started.
XDigger
Posted: 27 Mar 2018 at 11:00am |
It's not clear (at least to me) that this was defective out of the chute. It sounds like it was working initially, and then something went wrong. What we don't know is whether power is getting to your converter, or whether you have a bad circuit breaker, or if something went wrong with the converter itself.
Even though the dealer is not an Rpod dealer, I would expect them to be able to figure this out. It's not rocket science, and pretty much all travel trailers have a converter. The main difference is the size. The Rpod is simpler than most. |
Posted: 27 Mar 2018 at 11:19am |
I doubt it was the furnace use that caused the problem. If it was working when you bought it, the breaker could have gone bad. That is not something that can be predicted. Now, is there possibly a short that instantly trips the breaker when you attempt to reset it? Try resetting it with shore power unplugged. If it resets, then look for a loose wire that is shorting and tripping the breaker immediately. If it still has the soft feel, then it is most likely the breaker has gone bad. I am not an electrician, so I can't help you further.
Page <123> |
