| Author | ||
podderfj
Joined: 13 Oct 2015 Online Status: Offline Posts: 61 |
Calendar Event: High Pointe Microwave/Convection OvenPosted: 25 Mar 2018 at 6:33pm |
Need some advice on my oven as listed in title. I have a 2016 Pod and this weekend while camping with shore power, the oven started acting up. When off and the door is closed, the light stays on and the glass plate turns. I can set the clock time and power level, but the oven will not set the cook time nor will it come on when I push the start button. Any advice on what might be wrong. It is about 2 weeks past warranty time(just my luck). Thought I might remove it from the camper tomorrow, bring it is house and see if it will come on. I know that I have to be careful as these things can give a strong punch of voltage, even while unplugged. I know there is a fuse in there somewhere, but I would assume if the fuse was bad, the oven would not do anything at all. If I cannot find anything wrong, i will probably just junk it and will be looking for a good replacement. Can any of you out there in pod land recommend a good replacement that will fit in the same slot as the high pointe? Any advice will be appreciated.
Posted: 25 Mar 2018 at 8:18pm |
Did you have a surge protector on your trailer's power line? If not, you might have caught a surge that fried something in the HiPointe's electronics. You don't say which model of R-Pod you have. In our 179, the CM plugs into an outlet inside the storage bin above the dinette. Find out where yours plugs in and unplug it. Wait a few minutes and then plug it back in. Does it behave normally now? If not, then something is likely gone bad.
As for replacements, you could look for a straight microwave if you don't use the convection part. That would likely cost less. Look for one that will fit the opening. If you want the convection oven part, then you may be stuck with getting another HighPointe. |
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2783 |
Posted: 25 Mar 2018 at 8:34pm |
Posted: 26 Mar 2018 at 7:16am |
Well since the high point, good or bad, is built and marketed to the RV world, and that top ten list.. isn't, I can understand the HP didn't make the list. |
Posted: 26 Mar 2018 at 7:43am |
+1 to Furpod. HPs are built for RV and mobile applications They are UL/CSA certified to over the road specifications. Basically designed to withstand vibration over the home use.
disputin
Joined: 03 Jan 2018 Location: WA Online Status: Offline Posts: 27 |
Posted: 26 Mar 2018 at 10:16am |
We have this exact problem with our Highpointe occasionally. It means the door didn't seat as well as it should and there is a switch not set. I find if I push on the upper right-hand part of the door, it will seat appropriately and the light will turn off and the turntable will stop. My thinking is somehow the microwave has gotten slightly torqued along the way and isn't quite aligned properly. It hasn't proven enough of a bother yet to think about replacing.
Sean & Christine Whitney 2016 179 2002 F150
voisj
Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
Posted: 26 Mar 2018 at 10:31am |
Disputin Quote We have this exact problem with our Highpointe occasionally. It means the door didn't seat as well as it should and there is a switch not set. I find if I push on the upper right-hand part of the door, it will seat appropriately and the light will turn off and the turntable will stop. My thinking is somehow the microwave has gotten slightly torqued along the way and isn't quite aligned properly. It hasn't proven enough of a bother yet to think about replacing. |
TheBum
Posted: 26 Mar 2018 at 10:40am |
It's always a good idea to either unplug it or flip off the breaker (it's on its own circuit) when not connected with a surge protector.
Alan
podderfj
Posted: 26 Mar 2018 at 4:02pm |
Thanks for all of your replies. Found my problem. The switches on the door were not making as mentioned above. Added a couple of layers of heavy duty duct tape to the contact switches and now all is well and working fine. Talked to High Pointe early in the process this morning and they told me to pitch it and they would send me another one for $250 plus $50 shipping. No way was I going to buy another High Pointe. This one is only just over a year old. Do, started looking and found the problem. Thanks again fellow ponders. Problem solved.
jacktherev
Joined: 20 Dec 2019 Online Status: Offline Posts: 2 |
Posted: 04 May 2020 at 7:16am |
My High Point began failing last winter on our 5 month trip in the south. For the first year we owned the LTV installed oven we only used the microwave portion and all was fine. After using the convection feature a couple of times the oven started acting weird: The light would come on and the table start turning whenever we plugged into shore power. Thinking the Unity power might somehow be the culprit I unplugged the High Pointe and ran an extension cord from a garage outlet and plugged it in. Same result. It took a lot of button pushing and door opening and closing to get the oven to the state where it would work at all - not something that gives one a lot of confidence since it is contained within a wooden cabinet!
