babyboogerfamily
Topic: New Pod Setup Posted: 06 Mar 2018 at 6:47pm |
Hello,
Our rPod is being delivered new from out of state. Other than what's clearly spelled out in the owners manual, what should I expect when gearing it up for real-time use for our first trip?
Thanks,
Posted: 06 Mar 2018 at 9:07pm |
Mostly "teething" issues.We found little tiny bits of plastic or something in the water pipes. They clogged the strainer in the kitchen sink a couple of times when we first used it. Also, it took a short wait (less than a minute) for the propane to reach the burner on the stove and the water heater.
Did you get a walk though with the dealer? Ours was very thorough, and we watched as they went through every single switch and compartment with us. This also included attaching/detaching the WDH.
actionhooper
Posted: 07 Mar 2018 at 7:13am |
Nice! Can't wait to see pics of it.
Posted: 07 Mar 2018 at 9:14am |
For the initial, other than the walk thru with dealer. Look for missing and lose hardware and things, bring it to dealers attention, any obvious damage, make sure your dealer does a good prep. Most important make sure your are ready and capable to tow. Your tow vehicle is ready. Other things will come out as you use trailer, fix them when they need. After I got mine home I found considerable construction debris behind panels, so I cleaned it. I also make sure fasteners are tight, etc. Happy Trails.
crw8sr
Posted: 07 Mar 2018 at 10:44am |
Construction dust in hidden places; remove the panels that you can and vacuum everywhere! Loose drain fittings. Flush and drain water tank and water heater. Supposedly done at the dealer but I did it anyway.
Hit the road and ENJOY!
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
Posted: 07 Mar 2018 at 12:55pm |
The good thing is that if you are not already pretty "handy" you'll quickly learn to be. Welcome and enjoy your Pod.
metaldpod
Posted: 08 Mar 2018 at 11:48am |
Just a heads up too, after reading some posts on here about the water/waste tanks I checked the screw fasteners holding the tanks up and found most of mine weren't snugged up and definitely looked unsafe. Returned to the dealer and they tightened them up and replaced a couple of them. I would also do a test run at home of the complete water system (sinks, shower, toilet), range, and see if refrigerator works all three ways (hooked up to power, 12volt, and propane). When we got ours I found out our dealer did a less than exemplary job at prepping ours (kitchen faucet leaked, water lines hadn't been flushed of anti-freeze, hot water tank valve not set to summer setting, refrigerator didn't work on propane). Also this site is a wealth of information for solving problems when they come up so having access to it when first starting out camping is a plus. You can also check Youtube, there are quite a few videos on Rpod features and operations.
David and Vicki Snyder, 2015 R179, 2012 Jeep Grand Cherokee
babyboogerfamily
Posted: 08 Mar 2018 at 8:34pm |
Thanks everyone for the helpful comments! This place is great.
rawest50
Posted: 12 Mar 2018 at 7:01pm |
The owners manual is very limited. MAK SURE you hold on to the equipment checklist. It has all your model numbers of the equipment. I made my own manual or lack of manual was worthless. See what you get and if does not comer everything let me know. I have operating instructions on most items.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
