Page 12> |
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2725 |
![]() Posted: 27 Feb 2018 at 7:28pm |
Bully, recommend a WDH with that tow vehicle, last time I weighed my 178, hitch weight was 372. Both my tow vehicles are rated at over 6000.
Bully ![]() Newbie ![]() Joined: 25 Feb 2018 Location: Mississippi Online Status: Offline Posts: 5 |
I will let you know very soon. We just bought a 178 and will be towing it with a 2014 ford edge 3.5 with a factory trailer package. I am installing a 6000 lb wd hitch with sway control when we pickup the trl tomorrow. The Edge is rated at 3500 lb and 350 hitch wt.
BB
texman ![]() Senior Member ![]() ![]() Joined: 24 Jul 2014 Location: TeXas Online Status: Offline Posts: 446 |
fwiw- i just completed a 750 mile round trip in our 2018 sequoia with WDH and anti sway and our 182g. this is the first trip that i have had the hitch and previously towed the trailer with a Tundra and no special hitch at all. I am really amazed at all the folks that manage with the smaller vehicles to tow the pods. I know highway speeds and winds are the biggest factors that influence the highway experience to me. i was fortunate to have a tail wind coming and going(never happened before). actually more of a diagonal crossing wind on I40 witch is mostly east/west where i am. The sway and WDH made all the difference in the world. Even with the new hitch, i still noticed some sway from wind shadows and passing semi trucks. i blame some of that on the factory tires(just ordered some carlisle tires to fix that) So, my 2 cents is get the WDH for full size and all others as well.
Texman |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6457 |
For a Ford Edge (or similar 3,500 lb rated vehicles) I believe it to be an absolute necessity--especially if you have front wheel drive. The weather does not matter. Without, you will not have sufficient traction even on dry roads. Please see the Ford Edge Trailer Towing Guide for more information (2017 version linked). Another consideration is that the Ford Class 2 towing package for the Edge only includes a 4-pin connector. A brake controller and 7-pin (Bargman) connector will need to be installed also. |
gaw0728 ![]() Newbie ![]() Joined: 26 Jan 2018 Location: VA Online Status: Offline Posts: 4 |
is w weight distribution hitch necessary we would not be towing in an extreme weather
gaw0728
I used to tow with a 2016 Ford Escape SE with tow package and 3,500 lb tow rating. I would likely still be towing with it except we encountered ice with a strong cross-wind in Wyoming in December 2016. I don't know if a larger tow vehicle with a higher tow rating would have made any difference. We now tow with a 2010 Nissan Frontier LE Crew Cab 4x4 with 6,100 lb tow rating.
Escape's advantages: 1. The 2 Liter Ecoboost engine is remarkable, especially at higher elevations where it is able to keep going at top power because of the turbocharger. The 4 Liter V6 in the Frontier loses 4% power for every thousand feet in elevation. 2. The short distance between the center of the rear axle and the hitch ball means less force can be exerted by the trailer. Trucks passing were like a gentle nudge, but no problems. Escape's disadvantages: 1. It (and similar vehicles with a 3,500 lb tow rating) have problems with wind resistance. Look in the owner's manual for towing guidelines. You will find that the R-Pods have a frontal area that is quite large and probably exceed manufacturer's recommendations for maximum frontal area. This can be mitigated a little by using a wind deflector such as Purpleline's AeroPlus or Icon's AeroShield. Still, limiting tow speed to 60 mph or lower will be a great help with mileage. Anything faster than 60 mph, you are looking at single-digit mileage, even on level ground. 2. Stowage: The Escape or Edge or any other SUV will not give you a good place to carry extra propane or, if you have a generator, extra fuel. Neither are really that good to carry inside the SUV with family. 3. Unless you get an All Wheel Drive version, expect traction issues. We had the FWD Escape. Even with a properly adjusted weight distribution hitch, starting out on anything other than dry pavement could have issues. AWD would help. Don't think you can climb hills on dirt roads. If you have to start from a stop on a hill, expect to spin the wheels at least. Snow and ice are to be avoided! I know from experience. |
does anyone tow with a Ford Edge or other SUV having a 3500 tow rating
gaw0728
twodues ![]() Newbie ![]() ![]() Joined: 31 Oct 2016 Location: Michigan Online Status: Offline Posts: 20 |
We have the same set-up as jimandclare except only anti-sway and ditto everything he/she/they posted. It even did well through the Ozarks and NW Arkansas.
Page 12> |
