Cametz
Joined: 09 Sep 2015 Location: Washington Online Status: Offline Posts: 3 |
Topic: Toilet paper roll - helpPosted: 19 Jan 2018 at 1:32am |
We have the 171 and I’m struggling with what to do with the toilet paper roll. Hubby won’t ‘drill’ into the walls - I use 3M removable hooks for everything else but can’t figure out how to mount something for the TP. I also need to be able to keep it dry when I shower. At this time the TP sets on the ground & I just place it outside the door when I shower.
Metz Häusle
Posted: 19 Jan 2018 at 9:02am |
We used a roll holder from Cottonelle..Many have bought water proof wall mount holders and installed them. There is at least one that gets set into the wall part way..
Posted: 19 Jan 2018 at 9:40am |
I'm not sure of the layout in the 171 bath. We have the 179. I use an over-the-tank spare roll holder purchased at Walmart. I reinforced the inside bottom edge of the plumbing opening in the wall behind the sink's bottom cover. The holder then hooks over it and holds the roll up off of the floor. I did find though that we still need to remove the roll when showering since there is enough splashing to get the bottom of the roll wet if we don't remove it.
CH OTT Roll Reserve |
TheBum
Posted: 19 Jan 2018 at 10:41am |
Industrial strength Velcro is always an option.
Alan
podenvy
Joined: 06 Jul 2015 Online Status: Offline Posts: 33 |
Posted: 28 Jan 2018 at 1:01pm |
2013 FJ Cruiser + 2015 rpod 179 HRE
Carolavan
Joined: 25 Sep 2016 Location: South Carolina Online Status: Offline Posts: 39 |
Posted: 04 Feb 2018 at 4:32pm |
I have thought about this topic too.The best solution is to do as you have done. When using the shower put the TP outside the bathroom. Simplest solution.
2015 R-Pod 179
2016 Nissan Pathfinder Platinum "It's a good thing we are going slowly because we might be going in the wrong direction." Ashliegh Brilliant |
