Page <123> |
| Author | ||
Olddawgsrule
Joined: 20 Sep 2017 Location: New Hampshire Online Status: Offline Posts: 1014 |
Calendar Event: Battery Disconnect SwitchPosted: 18 Dec 2017 at 7:23am |
Guess someone has to ask.. Teddy, have you double checked your meter?
From experience mind ya, when I don't get a reading I expect, I double check I'm set right on the DMM then check a known of same power source. Also, your looking for only 5v DC at the USB port. |
rawest50
Joined: 07 Mar 2017 Location: Arkansas Online Status: Offline Posts: 440 |
Posted: 18 Dec 2017 at 9:00am |
Since I am electrically dumb. If you install a battery disconnect switch what service does it perform? When would you use it?
2017.5 RPod 179
2017 Jeep Unlimited Wrangler 2017 Chevy Colorado Z71 Off Road Crew Cab 2 Weiner dogs Great wife puts up with my BS ❤️ Thoroughbred Racing.
Posted: 18 Dec 2017 at 9:11am |
If you store your Pod somewhere you can't plug in, the batteries will be dead in a very short time, due to phantom draws.. so this saves your battery. There are other reasons a owner may want one, but that's the main reason. |
ChetC
Joined: 17 Jul 2016 Location: Las Vegas, NV Online Status: Offline Posts: 43 |
Posted: 18 Dec 2017 at 1:34pm |
According to the NHRA Sanctioning body, battery cutoff switches should be installed on the positive side of the battery, which settles the debate for me. From their rule book... 8.4 MASTER CUTOFF
...This cutoff switch must be connected to the positive side of the electrical system and must stop all electrical functions... |
Former 2017 rPod 180 owner
Now in a 2019 Little Guy MAX Full timer who logs more than 35,000 miles per year. |
Posted: 18 Dec 2017 at 4:13pm |
+1
Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1456 |
Posted: 18 Dec 2017 at 5:51pm |
I completely agree, but electrically it makes no difference. The NHRA has other requirements about a cutoff switch, but I think their main concern with having it on the positive side is for uniformity. In the case of an accident with leaking gasoline and a possibly injured or unconscious driver, you want to know where the switch is. There's a lot to be said for uniformity even though it's your own private electrical system that maybe no one else will ever fool with. TT |
FJ Cruiser |
Olddawgsrule
Posted: 19 Dec 2017 at 7:06am |
If ever in doubt of which side to tie into DPDT. Removes all doubt.
MHO on the matter. |
Posted: 19 Dec 2017 at 1:37pm |
Despite what NHRA says, I was always taught connect positive first, then negative; disconnect negative first, then positive. That is why my disconnect is on the negative side. I don't think I will be racing my 'Pod, so I will stick with the old standard.
Posted: 19 Dec 2017 at 3:26pm |
I don't have a disconnect switch on my Pod so I haven't had to make this decision for myself. It seems like NHRA rules are dealt with by generally competent mechanics, which may be a factor in choosing to switch the positive side. I don't really know, but I suspect they tend to use specialized, fused switches that may have a lot more spark protection than a cheap RV cutoff switch.
For amateurs, using a cheap knife blade cutoff switch, I think putting the switch on the negative side is probably the best way to go. Those switches are almost pure metal conductive surface that greatly increases the possibility of an accidental short circuit. There are slightly more expensive switches that have no metal exposed that should probably be used if one insists on putting the switch on the + side. They tend to be a little more effort to install too. Electrically, it makes no difference. A good switch, competently installed will work on either side. For a casual installation, especially of a knife blade switch, the negative side is the way to go. Yes, I'm pretty much switching my answer! ![]() TT |
FJ Cruiser |
Olddawgsrule
Posted: 19 Dec 2017 at 3:32pm |
The real answer depends on the reason. Also why I say, if in doubt DPDT. No chance on any feedback of power both sides are dis-connected. I bought my transfer switch for the house because it is a DPDT. No possibility of any feedback to the folks working the lines out there trying to get me grid power back. |
Page <123> |
