TEDDY
Topic: 2017 178 - USB PLUGS Posted: 14 Dec 2017 at 3:31pm |
There are two USB ports on the wall near the TV - they don't seem to charge my phone. Any ideas?
Teddy
Posted: 14 Dec 2017 at 4:06pm |
They make USB testers, 5-15 bucks, Amazon sells, I think WalMart does too.
JandL
Posted: 14 Dec 2017 at 4:20pm |
They may require 120 volts AC. They do make DC ones that plug into a cigarette lighter
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
RichC
Posted: 14 Dec 2017 at 4:24pm |
I've noticed that the usb on my Jensen unit doesn't work well. It cuts off. Did I miss something in the manual which I only skimmed?
I also installed the combo 12 v plug, usb port, and battery gauge (which I really like). So, not a major issue.
Posted: 14 Dec 2017 at 4:32pm |
I have an older model 178, so I installed 12V plug, USBs and gauge. Works fine. Only comment is my USB ports work off 12V.
TEDDY
Posted: 14 Dec 2017 at 8:08pm |
I'll look for a USB tester...... Thanks.
Teddy
RichC
Posted: 15 Dec 2017 at 12:47pm |
It occurred to me that the USB plug on the Jensen is not for charging but only for media input. Am I having a "D'OH!" moment? Where did I put that manual?
TEDDY
Posted: 15 Dec 2017 at 1:39pm |
YES - the Jensen USB port is for input - not for charging or output. I ordered a USB tester from Amazon - Walmart store doesn't carry them (only on-line).
Teddy
Posted: 15 Dec 2017 at 9:05pm |
Teddy: do you have your pod plugged inyo shore power when you are trying to charge with the USB p;igs?
2011 R-Pod 177
2010 Ford F-150
TEDDY
Posted: 15 Dec 2017 at 11:52pm |
Yes - shore power. The USB tester should come by Monday so I can check it out.
Teddy
