Page <1 234 |
WillThrill ![]() Senior Member ![]() ![]() Joined: 04 Jul 2014 Online Status: Offline Posts: 298 |
![]() Posted: 06 Dec 2017 at 3:04pm |
Honestly, if you aren't going to be running the furnace much or connecting an inverter to your Pod, you probably don't need to spend the money on a solar panel. Your LED lights draw almost nothing, and your water pump can run a long time on your battery, a lot more than your fresh water tank capacity. If your battery does drop to 50% (about 12.2 volts, easily measured), you can recharge it from your running vehicle with a pair of jumper cables. Just connect positive to positive and negative to negative and run your vehicle for about an hour. We have another active thread as well where I discuss how you can do this with a charge controller; it's healthier for your Pod's batteries, but if you aren't using jumper cables regularly, it will be just fine for the occasional charge.
If you're still really wanting a solar option, I recommend this thread.
2014 Hood River 177 2005 GMC Envoy XL |
JET ![]() Groupie ![]() Joined: 13 Jan 2017 Location: Ashland, Oregon Online Status: Offline Posts: 72 |
Hi all
I know that this must be a previously discussed question, but I never seem to have any luck with the forum's search feature in finding previous articles. Anyway, I have a 2017 178 and would like to buy a suitcase solar panel for dry camping. I want to stay at a modest budget of $300 or less (hopefully $250 or less). I really know nothing about this subject so any advice would be appreciated. When dry camping I do not plan on using much electricity, but would simply like to be out a week or two while using minimal lights, radio etc., without the batteries going under the recommended charge levels. My R-Pod has 2 6V golf cart batteries. When I buy a suitcase solar panel I want to make sure I have 100% of all necessary items to hook it up and utilize it. I know that my R-Pod is prewired for solar, but that is about the extent of my knowledge :) I would of course like to buy the best unit available for my budget. Thanks in advance for any and all suggestions and information. Sincerely, John
Page <1 234 |
