Page 12> |
Lakeway Rpod
Joined: 15 Nov 2017 Location: Texas Online Status: Offline Posts: 7 |
Topic: Water Heater on PropanePosted: 15 Nov 2017 at 1:41pm |
Hello out there. Just received my 2018 Rpod 178. So fun. For some reason the water heater using propane stopped working. I can heat water using electricity, so the heater works. One note, the DSI light next to the water heater switch in the unit stays on. Any ideas? Thanks so much!
Posted: 15 Nov 2017 at 1:49pm |
That would indicate an ignition failure. If it is convenient for you to get back to the dealer, take it there and have them fix it under warranty. Otherwise, try the reset buttons that are behind the cover. I don't know if that will help, but it can't hurt.
I'll take it for granted that you checked to see that you do have propane in the tank and that the valve is turned on. |
Lakeway Rpod
Posted: 15 Nov 2017 at 2:13pm |
Thanks so much. There is propane and it's on. I tried the reset as well. Still does not work. As it turns out, I called the dealer right after my post and I will be there tomorrow.
I really appreciate the quick response!!!
Larry-D
Joined: 12 Oct 2017 Location: Middle TN Online Status: Offline Posts: 113 |
Posted: 15 Nov 2017 at 2:31pm |
Try unplugging the controller board, wait a few seconds and plug it back in. Our larger trailer had a bad board from the factory and with distance and aggravation it was cheaper to order a new board from Amazon and replace it. 5 minute job.
Lakeway Rpod
Posted: 15 Nov 2017 at 2:43pm |
I will check it out and bring it up to the dealer tomorrow. Thanks!
riotkayak284
Joined: 29 Apr 2016 Location: Nashville, TN Online Status: Offline Posts: 162 |
Posted: 15 Nov 2017 at 4:00pm |
I have had to run my propane stove for a minute or 2 to remove air from the lines.... assume you have tried that.
Lakeway Rpod
Posted: 15 Nov 2017 at 4:33pm |
I did. It worked the first time I used it, then stopped.
MDPaddlersPod
Joined: 06 Jul 2016 Location: Maryland Online Status: Offline Posts: 135 |
Posted: 15 Nov 2017 at 4:53pm |
Where is the reset button, I am having the same issue.
MDPaddlersPod
2017 RPod 179 2002 Silverado1500 |
Posted: 15 Nov 2017 at 5:16pm |
The resets are on the left hand side of water heater, under a rubber cover. The interweb has many Suburban WH troubleshooting sites, if you don't have a warranty. Google is your friend :)
Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1455 |
Posted: 15 Nov 2017 at 6:46pm |
Check the simple things first. Is the gas on at the tank? You said the stove worked and then quit? Maybe you're out of propane??? TT |
FJ Cruiser |
Page 12> |
