  New Posts New Posts RSS Feed: Plumbing air pressure test?
Topic ClosedPlumbing air pressure test?
Keith-N-Dar View Drop Down
Direct Link To This Post Topic: Plumbing air pressure test?
    Posted: 09 Nov 2017 at 5:11pm
Most use a regulator.  They are inexpensive and easily put in line to the water inlet.  I don't know that they are needed in most campgrounds but they don't hurt.
2011 R-Pod 177
2010 Ford F-150
CharlieM View Drop Down
Direct Link To This Post Posted: 09 Nov 2017 at 6:13pm
Always either check CG water pressure and/or use a regulator. I have seen CG pressure as high as 100psi. The Fairview WR-RV55 is a good one in that it permits high flow rate for showers while limiting pressure to 55psi.
Direct Link To This Post Posted: 09 Nov 2017 at 7:32pm
Great point brought forward JandL differentiating between hydraulic and air pressure.  I have just finished blowing out irrigation lines on 3 golf courses over the last 3 days and while we maintain 120 - 125 lbs of water pressure in the lines during the summer using the 375 CFM air compressor we may get up to 36 - 38 lbs air pressure in those same lines while blowing out/purging water out of the lines.  When water is purged and air comes out of the sprinkler heads, the sound is something like a jet ready for take-off.  This is especially true at the end when we open a 2" line to let the air out quickly so we can disconnect the hose, this takes about 12-15 minutes.  When the air comes out you better have on some really good ear protection otherwise you will end of going deaf or ruining your hearing, the sound of the air escaping is deafening.
