  New Posts New Posts RSS Feed: Solar panels
Topic ClosedSolar panels - Event Date: 02 Nov 2017 - 02 Jan 2018
Direct Link To This Post Calendar Event: Solar panels
    Posted: 07 Nov 2017 at 5:27pm
Good to know. Looks like we are going to get 2 of the 100w panels and give it a try! We did some boondocking as part of this last trip and enjoyed it. So we are going to give it a try on our next trip to the outer banks and points south.
sailor323 View Drop Down
Direct Link To This Post Posted: 08 Nov 2017 at 6:20pm
Just a little additional info.  Most panels are rated in watts.  Appliances are rated in watts.  Batteries,  on the other hand are rated in amp hours.  To convert watts to amps (at 12volts), divide watts by 12 to get amps.  This is useful because you need to know to try to keep track of how much of your battery bank you are using.  If you go with 2 6v batteries, you will have a total capacity of bout225 amp hours (265 if you go to a slightly higher capacity battery) or useable capacity of half that.  So, for example, y.our fantastic fan draws 2.8 to about 4.5 amps depending on speed.  Over a 10 hour period, it uses 28 to 45 amp hours.  Your 12 v coffee maker probably will use about 13 amps; probably OK for short periods 15 minutes will use about 3+ amps (though I really like our French press)
rumman View Drop Down
Direct Link To This Post Posted: 08 Nov 2017 at 6:59pm
All I do is boondocking and I have a 160 Watt solar panel installed on the roof which is juicing two 6 volt batteries and they are four years old. I am always charged up everyday so that I can fire up the furnace every night and use the TV daily. It will not run the microwave or the AC but that okay I live and camp where its not too hot so that's fine I also carry a 2000 watt Yamaha generator/inverter which was also a great investment. The generator is used for just in case circumstances. The solar panel and 6 volt batteries are the best investment that I ever made, I would not be without that set up in the future.
Good luck in whatever set up you choose.
2014 RPod 179 towed by 2016 Chev Colorado (V6).
Direct Link To This Post Posted: 08 Nov 2017 at 8:11pm
Guys,
I really appreciate the info! Really looking forward to giving it a try!
Thanks
