Page <1234 5> |
Topic: LevelingPosted: 15 Oct 2017 at 9:02pm |
It was not the Andersen leveler as such, but before I poured the extension, the slope of the driveway was such that leveling our R-Pod needed more than 4" of lift. I was trying to use a 2x10 under the Andersen leveler and could not figure out how to stop it frrom slipping, even though I tried using some non-skid material between the board and the leveler. With the extension, I think the Andersen leveler by itself will be sufficient so I wuld not have the same issue as I had before. |
rawest50
Joined: 07 Mar 2017 Location: Arkansas Online Status: Offline Posts: 440 |
Posted: 16 Oct 2017 at 12:19pm |
Slipping? Sideways or in the direction of the tow hitch? The Anderson is only for left and right leveling. Up to 4". I have an electric jack for front to rear leveling and I do chock the opposite tire from the Anderson leveler. I do not want my jack holding the trailer in place. Just to level. We were on a fairly steep pad and my jack slipped about an 1". That is when I realized I need to chock the other wheel before taking it lose from the tow vehicle. No problems since. |
2017.5 RPod 179
2017 Jeep Unlimited Wrangler 2017 Chevy Colorado Z71 Off Road Crew Cab 2 Weiner dogs Great wife puts up with my BS ❤️ Thoroughbred Racing.
TheBum
Posted: 16 Oct 2017 at 12:23pm |
+1 for the Andersen. We had the BAL and managed to damage the screw using a battery-operated impact driver. The Andersen lets the TV do all the lifting.
Posted: 16 Oct 2017 at 12:46pm |
Not sideways. When I was trying to use a block under the Andersen to gain the additional height, the Andersen leveler would slide instead of the tire rolling up onto it. If it did start, then when I let off the brake, the Andersen would slide and pop out from under the tire. That does not occur if I am using it directly on the concrete. It also has not slipped when directly on blacktop or gravel or ground. It was only when trying to use it on top of a 2x10 piece of lumber that it slipped. I really like the Andersen leveler, but if you need more than 4" of lift, you will need to go with an alternative unless you can figure out how to keep it from slipping when placed on top of a piece of lumber. |
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2780 |
Posted: 16 Oct 2017 at 1:36pm |
ron_whitt
Joined: 08 Sep 2011 Location: Chesterville On Online Status: Offline Posts: 261 |
Posted: 16 Oct 2017 at 4:13pm |
RMP, we use the BAL, really like it. Chock and leveler at same time, drive into site, and only 1 person to level. I also use a set of chocks on the off side of the BAL, just for safety sake. Bonus is, you get more than 4in of lift.... LOL that being said.. if you need say more than 5in, your on the side of a mountain... I can and have the pod leveled side to side, front to back, by myself in under 5 minutes from getting out of the tv.
Ron & Shirley
2020 Tacoma 2012 177 rpod |
Larry-D
Joined: 12 Oct 2017 Location: Middle TN Online Status: Offline Posts: 117 |
Posted: 25 Oct 2017 at 8:15am |
After using 2x6s for year I finally sprung for the Anderson levelers. Big improvement. Quick and easy, heavy duty. Once level I use the corner jacks to stabilaize and everything is good to go. 5 minutes at the most.
rawest50
Posted: 25 Oct 2017 at 3:39pm |
They make a pad for the Andersen levelers. Says it can be used on dirt, grass, sand, slick pavement, etc. I do not have one so I cannot say if it works or not. |
2017.5 RPod 179
fwunder
Posted: 25 Oct 2017 at 4:58pm |
Another method...NOT!
On a recent trip, while wife was cooking dinner in the pod and I was enjoying a cocktail or three under the dome I was struck with a great (read, Don't do this!) idea! The pod was slightly pitched toward the slide side. No levelers. Dome always fits a bit better when level or slightly pitched toward dome side. "How much time before dinner?" I asked. "Ten minutes", she says. "Plenty of time", I think. I really haven't had much opportunity to use the hydraulic floor jack I carry. This seemed like a perfect time! I sat my cocktail down and got to work. Figured one Lynx leveler would do it and the dome would fit perfect! Slid the jack under the axle riser and slowly pumped the pod up. Didn't want to scare the wife or mess up my dinner. Of course, you gotto raise quite a bit to lift the tire and slide a Lynx leveler under it. I got it all the way up and leveler under and she didn't say a word. Surprised me. I was a bit too confident... It's generally a good idea to very, very slowly release the hydraulic valve to lower the jack. I was so proud of my new found leveling method, I sorta forgot and gave the valve a crank. Pod came down with a crash. Surprised me. Scared the sh*! out of wife in the galley. She came running out thinking someone just drove into our Pod! "It's all good Hon. We're perfect now!" I tried to sound convincing and confident. "Don't EVER do that again!" she quietly exclaimed in a slightly above average campground voice. Suffice to say...I won't do that again. Should make sure the level is exactly where I want it before putting dome up and definitely before cocktail hour! Or, buy an Anderson leveler. fred
Joined: 03 Apr 2011 Location: Mayville, WI Online Status: Offline Posts: 1447 |
Posted: 25 Oct 2017 at 7:46pm |
I am always concerned when I hear "hold my beer while I."
Page <1234 5> |
