Page 12> |
Tars Tarkas ![]() Senior Member ![]() ![]() Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1455 |
![]() Posted: 22 Oct 2017 at 6:37pm |
Yeah, I hope we hear back too. It's nice when someone's suggestion really helps, but it's also a problem we'd all like to see resolved. Maybe we'll learn something new...
TT |
FJ Cruiser |
Funny, you're cool. I reset mine today and TV and stereo worked, no fridge, microwave or AC, hope to hear back on this.
Ha! One would think spelling GFCI wouldn't be too hard.
TT |
FJ Cruiser |
+3 to GFCI
After checking all of the above, if you still don't have power, see if you can hook up to another power pedestal.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6463 |
If you have a digital multimeter or a circuit tester, check the pedestal outlet to make sure it has power. It could be the problem is not in the pedestal, but upstream from there.
Could be the CFCI needs to be reset.
TT |
FJ Cruiser |
Outbound ![]() podders Helping podders - pHp ![]() ![]() Joined: 19 Nov 2009 Location: Oshawa, Ontario Online Status: Offline Posts: 767 |
I've seen campground pedestals that:
But, I've never seen one that is working that wouldn't power my r-pod. Of course, you may have accidentally flipped a breaker in your r-pod. Have you tried turning all of them 'off' then 'on' again (note: sometimes when a breaker blows, it doesn't move enough to be clearly visible) Other than that, its time to pull out your 15-to-30 amp adaptor and use one of the 15a sockets on the pedestal.
My first step would be to shut off power at the pedestal, then check connection at the trailer. It is a twist lock plug, so make sure the connection is good, and the retaining ring is tight. then set the breaker at the pedestal and try again. If still no power then check the main breaker in the trailer by turning it off then back on. If still no power I can't think of much yu can check without a meter.
"power is clearly available"... How do you know? You see sparks when you disconnect and connect? Please say "no".. "We always turn off the pedestal breaker before hooking up or unhooking..."
assuming you have power TO the Pod, the next thing to check is the breakers. Make sure they are not tripped, make sure they are seated fully, make sure the wires are all tight. (disconnect from the pedestal BEFORE doing anything more then flipping a breaker) Check the GFCI outlet. Lights are on the 12v side. So if you have battery, you should have lights. In fact if you have 12v, the only things you shouldn't have is outlets, microwave, a/c, fridge and WH on 120v. Without knowing what Pod model you have, can't say what the stereo should be doing, but MOST are 12v. Some are 120v. |
Page 12> |
