  New Posts New Posts RSS Feed: Domestic refrigerator gas operation
Topic ClosedDomestic refrigerator gas operation - Event Date: 14 Oct 2017 - 20 Oct 2017
mwillfish View Drop Down
Direct Link To This Post Calendar Event: Domestic refrigerator gas operation
    Posted: 14 Oct 2017 at 11:22am
When we try to turn the refer to operate on propane we get the gas insignia and red triangle warning flashing. Unit does not start.
Should we leave it on longer? Or have it serviced.
Pod People View Drop Down
Direct Link To This Post Posted: 14 Oct 2017 at 12:00pm
Several things to check and do:
make sure the gas is turned om
light the stove and let it burn for 30 seconds to make sure all of the air in the line is removed
make sure you have battery power or plugged in
try the ignition now-it may take several attempts-you should be able to hear a clicking sound of the igniter if you are outside next to the service panel
good luck
Vann
Vann & Laura 2015 RPod 179
TheBum View Drop Down
Direct Link To This Post Posted: 16 Oct 2017 at 12:35pm
It's not unusual for you to have to reset the alarm a couple of times before it finally ignites, particularly if it's been sitting idle for a few weeks, even after bleeding the gas lines.
