  New Posts New Posts RSS Feed: Winter Camping
Topic ClosedWinter Camping
Direct Link To This Post Topic: Winter Camping
    Posted: 05 Oct 2017 at 8:15am
+1 to SH on insulating windows, especially bed area. That makes a big difference. Would also look at a ceramic heater and definitely a heated water hose.
Direct Link To This Post Posted: 04 Oct 2017 at 8:41pm
+1 on no special prep needed since you say daytime temps will be well above freezing. Plus, you will be running the furnace or some other form of heating. That will help also. We've made a couple of winter trips and found that as long as it is not prolonged freezing temps, the R-Pods handle it well enough.
Edit: You may want to get a roll of the insulation that looks like reflective faced bubble wrap at you local Lowe's or Home Depot store. Cut sections to fit the windows and slide them in behind the shades. It will help for when it does get cold. I also put some insulation underneath the bed platform. It seemed to help also. See my mods for details.
DavMar View Drop Down
Direct Link To This Post Posted: 04 Oct 2017 at 7:06pm
You might want to look into heating pads for your holding tanks but most likely unless you have a deep freeze I would think you'll be okay with just insulating your water intake line. Best of luck!
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 03 Oct 2017 at 11:11pm
You'll be okay at the temps you describe without any special prep.  You can get into the 20s at night as long as it warms up into the 40s during the day.  Sustained temps in the 20s will get worrisome.
HANSONS View Drop Down
Direct Link To This Post Posted: 03 Oct 2017 at 9:36pm
Yes it was a white out.
We are moving to Sequim Washington and will be staying at an RV park over the winter since our house will not be ready until next summer. The winters don't appear to be too bad here and we figured we needed to put insulation or film over our windows to help retain the heat inside. Also need to put a cover over the water line going into the trailer as well as insulating the hose. Not sure if we need to put skirting around the trailer or not.
The temperatures during the winter here average high 40's to low 50's during the day and around freezing at night. Not sure what else we need to do but any tips would be really helpful.
Karen H
Karen and Joel Hanson
2016 RPOD 179
Direct Link To This Post Posted: 03 Oct 2017 at 9:17pm
Must be a white-out. Smile Please try again. Also, welcome! We have a 2016 RP-179 also.
Direct Link To This Post Posted: 03 Oct 2017 at 8:50pm
2016 RPOD 179
