  New Posts New Posts RSS Feed: Overnight scenerio
Topic ClosedOvernight scenerio
JandL View Drop Down
Direct Link To This Post Topic: Overnight scenerio
    Posted: 28 Sep 2017 at 10:39am
You can measure pin 4 (12 volt charging) at your trailer connector on the truck and if you see 0 volts with the key out of the ignition if you see 12 volts then it will not drain your truck battery.
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
Subzilla View Drop Down
Direct Link To This Post Posted: 28 Sep 2017 at 9:47am
For one night, I left it plugged up.  You have the Pod battery plus the TV battery.  One night won't discharge both.  Initially, I did think about unplugging it though for the very reason you are concerned about.
Mark
Concord, NC
2017 RP 179 "Podzilla"
2011 Silverado 1500 4X4
voisj View Drop Down
Direct Link To This Post Posted: 28 Sep 2017 at 9:40am
In my truck (2013 F150) there is no 12 volt power being sent to the pod when the key is off, I have checked.
SLOPODMODS
John&Sue,SLO,CA
henryv View Drop Down
Direct Link To This Post Posted: 28 Sep 2017 at 9:13am
Let's say you are on a trip. You decide to pull into a Walmart parking lot and sleep. Should you disconnect the electric cable or not? If I run say the fan and lights (or tv), can I safely know I can start up in the morning and not need a jump start???
