  New Posts New Posts RSS Feed: Fresh water tank vs city water
Topic ClosedFresh water tank vs city water
Luv2Q View Drop Down
Direct Link To This Post Topic: Fresh water tank vs city water
    Posted: 30 Dec 2014 at 10:12pm
Makes sense.  Thanks, Craig.
John & Teri
Tundra 5.7L V8 / RP 180
Outbound View Drop Down
Direct Link To This Post Posted: 30 Dec 2014 at 10:04pm
Yes, if you connect to city water, your pump and fresh tank will be overridden and you'll use city water.
Originally posted by Luv2Q
(by means of check valves?)
Its not a very sophisticated approach, but, yes.  The check valve is only there to make sure that your pump doesn't push water out the city water connection.  Your pump itself keeps city water from filling the fresh tank.
If you have pressurized the water lines with city water, your pump won't activate.  I suppose that, if you have really low city water pressure, your pump may come on, drawing water from your fresh tank, to bring the lines to full pressure... but it'd be a rare occurrence; and of course, you'll have had to turn on the electrical switch to the pump as well.
Direct Link To This Post Posted: 30 Dec 2014 at 9:15pm
If I have water in the fresh water tank and then connect to city water, is the fresh water tank then bypassed?  I'm thinking yes (by means of check valves?) but not sure.
Goofy question, I guess, but will appreciate someone clarifying for me.  TIA .. Tongue
John & Teri
