  New Posts New Posts RSS Feed: New RPodder, quick question
Topic ClosedNew RPodder, quick question
Direct Link To This Post Topic: New RPodder, quick question
    Posted: 10 Apr 2013 at 9:51pm
Good to hear.
dsmiths View Drop Down
Direct Link To This Post Posted: 10 Apr 2013 at 9:43pm
Susan is a great gal , she has helped me many times in the past.
Dane and Donna Smith
2011 RP-172
lift kit
EEBowHunter View Drop Down
Direct Link To This Post Posted: 10 Apr 2013 at 8:01pm
Make sure you hook up the battery and the pod to charge it overnight at least every 30 days, when its is warm.  In the coldest months you can get away with 2-3 months.
Many of the earlier pods had to get the regulator replaced due to pinging under high load - mine included.
techntrek,
I contacted Susan Thornberg at Forrest River regarding the pinging issue and she said it was a known issue and related to the pigtail/regulator.  Fortunately she was nice enough to offer to send me replacement parts gratis Smile  Point taken on the battery...will do.  Much appreciated for the information Smile
Direct Link To This Post Posted: 09 Apr 2013 at 9:16pm
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 08 Apr 2013 at 9:38pm
Maybe you can teach it a new song...
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 08 Apr 2013 at 8:38pm
bhamster...that's what I was able to deduce.  The lady I bought the pod from kept the battery disconnected and stored in the trailer when it wasn't in use.  I just followed her example but noticed that every time I connected the battery and went inside the trailer the refrigerator was on but when switched over to propane would never attempt to ignite.  Now if I can only fix this "singing"/"pinging" propane regulator it'll be good as new Big smile
Direct Link To This Post Posted: 08 Apr 2013 at 8:34pm
Huh, I'll have to try this on mine.
bhamster View Drop Down
Direct Link To This Post Posted: 08 Apr 2013 at 4:29pm
Interesting... so if you lost power for some reason (in this case, you disconnecting it) then it doesn't try to start again?
Direct Link To This Post Posted: 08 Apr 2013 at 3:31pm
The pod stays out at my property permanently.  When we leave & button everything up I was disconnecting the battery and storing it.  Well when I would connect the battery the refrigerator would power up but it had never been turned off prior to disconnecting the battery so for some reason it just never tried to ignite the pilot.  It wasn't until after I power cycled it (with the battery connected) that it tried to ignite the pilot.
Direct Link To This Post Posted: 08 Apr 2013 at 3:20pm
Originally posted by EEBowHunter
all I needed to do was power cycle the refrigerator on the propane setting
ConfusedI'm confused... what were you doing before?
