  New Posts New Posts RSS Feed: Water heater 2020 RPod 190
cfishkin View Drop Down
Post Options Post Options   Quote cfishkin Quote  Post ReplyReply Direct Link To This Post Topic: Water heater 2020 RPod 190
    Posted: 18 Nov 2025 at 3:16pm
Thank you. I'm looking at the weather, and it will be a balmy 53 on Friday. That may be the day to fill it up and see what I can see.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 8:28pm
At this point, if weather allows and you haven't winterized yet I would have someone add water to the system and with a flashlight you can inspect all the lines in, and around the water heater; there has to be some obvious leak.  Otherwise, it will have to wait until spring unless you know of someone who has a heated garage that your 190 will fit inside of.
Post Options Post Options   Quote cfishkin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 6:35pm
Thanks for your reply. Yes, my low point drains are of the valve type and do not appear to be leaking. Still cannot figure out how my water heater lost all its water over a few months.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 5:20pm
Are both your low point drain (LPT) caps on and intact?  Check the rubber o-rings on the end of these, they may be cracked or missing.
Post Options Post Options   Quote cfishkin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2025 at 10:41am
One additional comment. When winterizing, and turning the valves for the antifreeze, there was no obvious leak under the water heater, but of course it did sit for 5 months without use and may have dried up? It is 6 gallons though and there should have been some evidence of a 6 gallon water spill.
Post Options Post Options   Quote cfishkin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2025 at 10:25am
Used the 190 a couple of times earlier this season without issue. Got busy later in the season and was not able to use it. Started to winterize it last week and removed the anode rod to drain the water heater and it was empty! I've never experienced that in the 5 years of ownership. I am not aware of any way to drain a water heater other than the anode rod.
How could that be? I must have a leak? Best guesses where? I'm at a loss.
Thanks.
