Replacement two-burner cooktop recommendations |
Post Reply
| Author | |
GlueGuy
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2792 |
Post Options
Quote Reply
Topic: Replacement two-burner cooktop recommendationsPosted: 31 Aug 2025 at 1:57pm |
I also found one made by Dometic; sold by Panther RV products.
poohbill
Joined: 22 Aug 2019 Location: Idaho Online Status: Offline Posts: 140 |
Post Options
Quote Reply
Posted: 30 Aug 2025 at 10:19pm |
Thanks. I recalled the job had been fully described earlier as a total replacement, and a number of assemblies with lids were available online. Never got around to it.
2016 179 Gastropod
2017 Ridgeline |
Rpod-Couple
Joined: 21 Jun 2021 Online Status: Offline Posts: 73 |
Post Options
Quote Reply
Posted: 30 Aug 2025 at 9:48pm |
Are you wanting to replace your current surface mount 2-burner gas cook top with a recessed one with glass cover? If so, check out the Suburban website. They have recessed 2 and 3 burner cook tops. (My 2021 171 uses a recessed Suburban cook top with a hinged glass cover that is flush with the counter top. You will have to verify you have sufficient depth. You will also need to cut a slightly larger opening in your countertop with a saber saw.
I would not recommend recessing your existing surface mount cook top. You would need to fabricate a metal pan larger than your existing burner to protect the counter top edges from heat damage.
Steve & Elaine
2021 R-pod 2023 VW Atlas Cross Sport |
poohbill
Post Options
Quote Reply
Posted: 30 Aug 2025 at 2:54pm |
This has been discussed before, but Search isn’t returning any hints so I’m calling on institutional memory of successfully sinking and covering the two-burner cooktop that came with my 2015 RP-179. Nothing shows up at etrailer, and Amazon has a plethora of new design but without covers.
Thoughts?
2016 179 Gastropod
2017 Ridgeline |
Post Reply
