  New Posts New Posts RSS Feed: Towing ?
Towing ?
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Topic: Towing ?
    Posted: 15 Jan 2024 at 10:07pm
Okay, one caveat to that is most modern vehicles have a "smart" alternator. When we did the conversion to LiFePO4 battery, I found that the tow vehicle was getting power from the trailer. I started a trip with a full battery and the alternator just loafed because the LiFePO4 battery's voltage was high enough that the alternator's programming "thought" it i did not need to provide power. I ended up on that trip with a rather depleted LiFePO4 battery. I then realized that I needed to do something different so I added a DC to DC converter from Renogy. To power it, I added a dedicated circuit from the tow vehicle. I could possibly have used the 7-way connector and just disconnected the wire underneath the trailer and run a separate wire to the DC to DC charger, but I did it this way so that I could also put in a battery isolation solenoid. This is the one I bought:
I do have a write-up in my mods detailing that conversion. With the Grey Wolf which has solar, I got an MPPT controller that can also use the solar as well as the vehicle for input. I still have the DC to DC converter. I would be willing to part with it if you would like to put it to use.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2024 at 4:25pm
My neighbor told me that many existing lead-acid chargers will charge lithium batteries as long as you can set the max. voltage of the charger and as long as the charger does not have an automatic equalization mode.
mjlrpod View Drop Down
Post Options Post Options   Quote mjlrpod Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2024 at 11:56am
If I am replacing my flooded batteries with Lifepo4 batteries, do I need to do anything to my tow vehicle? It has a trickle charge, and I don't know if that will screw things up. Thanks
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
