New to the forum and R-Pod community |
Post Reply
Page 12> |
| Author | |
Dee
Joined: 08 Feb 2022 Location: Washington Online Status: Offline Posts: 6 |
Post Options
Quote Reply
Topic: New to the forum and R-Pod communityPosted: 12 Feb 2022 at 3:19pm |
Thanks!!
Joined: 25 Jul 2011 Location: Central KY Online Status: Offline Posts: 6128 |
Post Options
Quote Reply
Posted: 12 Feb 2022 at 3:05pm |
Go into your profile, and "edit signature"
Dee
Post Options
Quote Reply
Posted: 12 Feb 2022 at 2:49pm |
Newbie here...I have my R-Pod and TV now. Sure would like to add it to my profile. Maybe it's obvious but I can't figure it out. How and where do I add that info on my profile? Thanks a heap!
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3441 |
Post Options
Quote Reply
Posted: 12 Feb 2022 at 12:51pm |
After towing our 177 for 8 years with a couple different Explorer's we went with a 2011 F-150 with the 5.0L V-8 Coyote engine. Maybe I just had a lemon but that engine sucked oil like there was no tomorrow. We took a 6000 mile hike over 30 days into the Rockies and back to Michigan, ended up using 6 quarts of oil. Mechanic told me the Coyote engine was known to use 32oz. oil for every 1000 miles! Now my older 1994 F-150 also had a 5.0L. V-8 (not a Coyote) and would use about 8oz. oil after 10,000 miles using a synthetic oil, which I also used on the Coyote. That engine on the 1994 had 322,000 miles on it and had never had an engine issue, although it did need a new clutch and throw-out bearing after 240,000 miles. And, to change the plugs on that Coyote engine was not an easy task either. The newer 3.5L with ecoboost is a much easier engine to work on just to do the basics. And so far, although it doesn't have that many miles on yet, hardly uses any oil between the 10,000 mile intervals.
GlueGuy
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2791 |
Post Options
Quote Reply
Posted: 12 Feb 2022 at 10:09am |
This is true. We have a Tacoma with the 4L V6, and the F150 with the 3.5L EcoBoost. Despite the fact that the F150 is bigger and heavier than the Tacoma, it gets significantly better mileage than the Tacoma, and is way more powerful; especially in the mountains. If we are doing a trip of any mileage (without the Rpod), the F150 is our go-to vehicle because it is more quiet and more comfortable. When we're pulling the Rpod, the F150 does it with its eyes closed. That said, both pull the R-179 just fine as long as you stay in the flats. They get similar mileage numbers when pulling the Rpod. We would never pull the Rpod in the mountains with the Tacoma.
Dee
Post Options
Quote Reply
Posted: 11 Feb 2022 at 8:26pm |
I'm looking at an older one. 2013-2014. I can use the luck...along with my SIL.
Kup-Pod
Joined: 08 Jun 2017 Location: Guelph, Ontario Online Status: Offline Posts: 153 |
Post Options
Quote Reply
Posted: 11 Feb 2022 at 7:34pm |
LOL...Sounds like me back about a year ago... for me, my Ford master tech is my nephew :-). Everyone needs their "person" in these situations.
He recommended that I go with the 5.0l, so I did. Hey, if you're going to trust your guy, you gotta go with what they recommend:-) Good luck!
2017 RP-178
2021 F150 5.0l "Lead me on a level path" |
Dee
Post Options
Quote Reply
Posted: 11 Feb 2022 at 6:32pm |
I'm very lucky to have a master certified Ford tech as a son-in-law. He's got me covered. Going to test drive a couple tomorrow. I agree about the fuel economy. Looking at V6 with eco boost.
Kup-Pod
Post Options
Quote Reply
Posted: 11 Feb 2022 at 4:38pm |
Welcome to the forum! This is a fantastic resource for virtually any questions you might have.
If you're looking for a truck, make sure you look at the fuel economy regardless of the size. With the fuel management systems on the newer trucks, you'd be amazed at the fuel economy on the F150 as compared to a Tacoma or a Ranger. Either way, you'll be well equipped to tow an Rpod. Enjoy!
2017 RP-178
Dirt Sifter
Joined: 30 Dec 2018 Location: Right side OR Online Status: Offline Posts: 170 |
Post Options
Quote Reply
Posted: 11 Feb 2022 at 2:19pm |
Welcome and good for you for jumping in! Your thought on a half ton pickup with tow package will work. Our Tacoma did fine towing a 179 except in very strong headwinds. The Tundra doesn't know the 195 is back there, until we near a gas station of course :-) Have fun!
Greg n Deb 2020 195 HRE
'07 Tundra 5.7L., '17 Tacoma 3.5L. Both with tow packages 1 Puggle, 1 Chihuahua support staff |
Post Reply
Page 12> |
