Post Reply
| Author | |
Topic: Furnace problemsPosted: 07 Sep 2021 at 8:50am |
Furnace problems are caused by multiple things, so some detail about the problem would be very helpful.
1. No propane: tank is empty or turned off 2. Does not run: no 12V power or thermostat not set 3. Tries to run but does not fire up: See #1 or something wrong with the spark ignition. Could be wasp nest or other obstruction in the furnace flue. 3. Fan starts, but gas won't flow: Could be a stuck sail switch. Remove face plate and make sure sail switch can move freely. 4. Other problems: Unknown since we don't have details. Maybe this will help to get you started. Please post the details and if you get it fixed, the solution so it may be helpful to someone else.
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3443 |
Posted: 06 Sep 2021 at 11:42pm |
I believe OG nailed it!
Posted: 06 Sep 2021 at 11:29pm |
Can you be a bit more specific?
Rider131
Joined: 03 Apr 2018 Online Status: Offline Posts: 1 |
Posted: 06 Sep 2021 at 9:42pm |
Post Reply
