| Author |
Live2Camp
Topic: Anniversary Edition r-dome Posted: 08 Apr 2019 at 10:15am |
Originally posted by Pod People
We made the awning from a heavy duty tarp. we ordered the keder tape and sewed it to the edge of the tarp. A standard home sewing machine will do this. |
Adding to Vann's comments just in case it's needed/helpful - be sure to use a larger needle (#14 or #16), longer stitch and stitch slower. Stories abound but the one I most remember is a friend who threw off the timing of his brand new (home, not industrial) sewing machine by sewing too fast on canvas. The friend is a really good mechanic so I figure if he could make that mistake, anyone can.
2017 R-Pod 179 HRE (the green one)
His:Ford F150 double cab 4WD; Hers/mine:Tacoma V6 double cab 4WD
Still love rugged, diggin' comfy too
Pod People
Posted: 08 Apr 2019 at 9:16am |
We made the awning from a heavy duty tarp. we ordered the keder tape and sewed it to the edge of the tarp. A standard home sewing machine will do this. check the size of your rail-there are 2 sizes depending on the year/model. be sure to order the correct size keder tape. We used standard telescoping tent poles with guy wires.
Vann
Vann & Laura 2015 RPod 179
Ginch
Posted: 07 Apr 2019 at 10:25am |
True dat
Ginch
Posted: 07 Apr 2019 at 10:12am |
How did you make your awning?
Ginch
Posted: 07 Apr 2019 at 10:03am |
You must taste good. We’ve been all over ( Salt st Marie over to Quebec then down around Lake Huron and northern Lake Erie) Ontario in June and had no problem with flies or mosquitos.
Pod People
Posted: 31 Mar 2019 at 8:36am |
I forgot to include the picture of the awning Vann
Pod People
Posted: 31 Mar 2019 at 8:31am |
We have both-the rdome and an awning(8'x10') that we made. We use both depending on the circumstances. We use the rdome if we are staying more than a couple of nights, if it will be raining or if we need the extra space. we use the awning if we set up for just one night and need some rain or sun protection. sometimes the campsite isn't big enough for the dome, so we will use the awning instead.
I used 6" round pvc pipe with screw ends to carry the poles. the pipe is mounted under the pod frame and across the width.
Vann
Posted: 30 Mar 2019 at 3:50pm |
There is no doubt.. an awning is a one trick pony, the dome does the awning thing just fine.. but then it does so much more..
The dome is home.
Kimmie
Posted: 30 Mar 2019 at 2:34pm |
Love your response! I haven't got an r-pod actually..I'm fence sitting of either buying a new r-pod 191 or a used class c. I have learned a lot of info on r-pods on this site which has helped with my pro and con list for both purchases. Thanks again for the response on the dome, something else to think about.
Kimmie from Kansas Just passing thur LIFE
mjlrpod
Posted: 05 Jan 2019 at 2:48pm |
I;ve said it before, I love the dome. I really fail to see the attraction of the tiny awning even if I didnt have the dome. My dome is as wide as my pod. Usually awnings are a few feet shorter on each side of the pod. There is so little area under the awning in my opinion. I love the dome so much, i bought a clam last year so i could have even more screened area. The clam pavilion also comes with built in rain flies that roll up just like the dome. So rain or shine it gives me an additional 12 1/2 x 12 1/2 foot wide "indoor" structure.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
