  New Posts New Posts RSS Feed: LP/CO Dectector
Topic ClosedLP/CO Dectector
CYQX Discovery View Drop Down
Direct Link To This Post Topic: LP/CO Dectector
    Posted: 27 Apr 2017 at 6:46am
My detector keeps beeping, according to my meter the battery is fully charged and it doesn't matter if the pod is plugged into shore power or not.
If I hit the reset button it's fine for about ten minutes then it starts the imtermittant three beeps every few minutes routine.
Any suggestions?
mcarter View Drop Down
Direct Link To This Post Posted: 27 Apr 2017 at 7:53am
There is a post today in the Reviews and General Info section regarding a batch of defective CO detectors. Issue there was the detector was bad.
Direct Link To This Post Posted: 27 Apr 2017 at 9:00am
We had that happen. Had to replace it a month after we bought our 179. Dealer said they had a bad batch and replaced it under warranty.
Direct Link To This Post Posted: 27 Apr 2017 at 4:40pm
Been an ongoing problem for quite awhile.  We replaced ours after 2 years and that is a 2011 model built in January 2011.
ragadas View Drop Down
Direct Link To This Post Posted: 28 Apr 2017 at 6:55am
I've got a similar post in the Reviews and General Information section.
I disconnected the shore power and battery, cleaned all the connections and reconnected. That seemed to 'reset' the detector and all was fine until I had to close up the pod. After about an hour the detector started going off again (and I found another cup of moth balls).
Dave & Chris
RP 179
2011 Tacoma Access Cab
V6 6 speed manual.
