  New Posts New Posts RSS Feed: Newby with questions
Topic ClosedNewby with questions
mario View Drop Down
Direct Link To This Post Topic: Newby with questions
    Posted: 20 Apr 2017 at 5:55pm
Hello all. Last fall we bought a newly new 182G. I had been looking for a pod with the garage in the back for some time and happened to find one in Bozeman, about 90 miles from our home. Needless to say we were super excited. Drove down, made the deal, and headed straight to Yellowsone Park for 3 days. It was the first time in 40+ years of camping where we actually slept in a bed; I'll never sleep on the ground again. In the morning it was pretty cold but all we had to do was turn on the heater for a few minutes. Awesome!
We cooked in the garage and generally had a great time.Smile
We have a 2015 Tacoma with the tow package and it seemed to tow to trailer just fine. The truck downshifted on even slight inclines, but afterall it is only a 6 cylinder. I noticed that the trailer pushed down on the hitch to the point where the front of the truck was elevated just a little. This didn't seem to affect the steering. However, before we head to Utah I would like to reduce the weight on the trailer tongue and level out the truck. According to the specs, the hitch weight is about 380 pounds. Questions:Embarrassed
1. Can I reduce the tongue weight enough to level out the truck by loading all my heavier stuff (camping gear, propane, spare tire, firewood, etc) behind the axle of the pod?
2. Any idea what the minimum tongue weight can or should be?
Thanks for your help.
CharlieM View Drop Down
Direct Link To This Post Posted: 20 Apr 2017 at 6:19pm
The short answer is no. Full disclosure: I tow with a 2013 4.0L Tacoma, 4WD with a TRD supercharger. Any weight on the hitch will cause the Taco to droop. This is simple physics on any tow vehicle. Moving weight aft of the trailer axle in an attempt to reduce this is just asking for sway problems, a very dangerous situation. The trailer should be loaded for 10-15% of it's total weight on the tongue. Don't count on the advertised or yellow label weight. It is very unreliable and always optimistic. My experience, and that of most others, says you should use a WDH similar to the Fastway E2. It gives you weight distribution, sway control, and a greatly improved ride.
mcarter View Drop Down
Direct Link To This Post Posted: 20 Apr 2017 at 6:26pm
Best to let the Tacoma and 182 folks weigh in. The empty tongue weight is 380. Everything you add to the rear of the TT reduces tongue weight, like a teeter totter. But you need to be careful, a light tongue could lead to swaying. You may be a good candidate for a WDH, because your concern is hitch related and picking up the front end. I work on principle that tongue weight should be 10-15% of TT weight, not to exceed capacity. My 178 has a capacity of 3768 and my tongue weight is 377. Water in the fresh water tank is part of capacity.
Direct Link To This Post Posted: 20 Apr 2017 at 7:01pm
Great information. Sounds like the outfit would benefit from a WDH. So you know, the yellow tag on this unit says the dry weight is 3071 lbs. I estimate that Ill be carrying maybe 300 lbs of gear, which would be a total of about 3371 lbs. I weighed the tongue today and it was 370 lbs, which is about 11 % of the total weight of the trailer (dry). So it looks that it's within the 10-15% range.
Direct Link To This Post Posted: 20 Apr 2017 at 7:05pm
PS. I plan to weigh the pod on a scale so that I know for certain its weight.
Direct Link To This Post Posted: 20 Apr 2017 at 7:11pm
I think you are on the right track, you will be an expert soon.
Direct Link To This Post Posted: 20 Apr 2017 at 9:09pm
Welcome to the group!!
Previously owner
texman View Drop Down
Direct Link To This Post Posted: 21 Apr 2017 at 9:20am
Mario
I have a 2015 182g, they are the pick of the litter (i think)  Anyway, i tow with a Tundra crew max 5.7ltr and i am looking at getting a WDH with sway control. I have made many trips with a normal hitch and no problems.  I really think that when added the lift to the pod, it did contribute to sway.  But, I live and travel in the windiest, gustiest part of the world i think.  I just dont like getting a wiggle at 70mph, no matter how small.  sure i could slow down, and i do.  But the wind and the trucks on interstates are not enjoyable, especially crossing winds and wind shadows.  fwiw.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 21 Apr 2017 at 10:08am
Thanks Tracy. I am thinking of upgrading to a full size truck for more towing power and less down-shifting of the Tacoma. Maybe a late model Tundra or Silverado. I'll just have to see how the Tacoma does this summer. You said "I really think that when added the lift to the pod, it did contribute to sway." Can you clarify?
Direct Link To This Post Posted: 21 Apr 2017 at 10:15am
i added a lift kit to the pod.  The kit raises the pod at the axle giving the pod more ground clearance and less likely to drag the jacks or sewer drains on something.  The kit is a piece of steel that fits between the frame and axle of the pod. I like the lift it gave, but i think it does cause the pod to be a bit more of a wind catcher and it does raise the center of gravity as well.  If you have an HRE edition, it is already lifted.
dont have a pic of the actual lift kit, just of the pod after the lift.
TexMan 2015 182g
2018 Sequoia
TexManMods
