  New Posts New Posts RSS Feed: Emptying Fresh Water Tank
Topic ClosedEmptying Fresh Water Tank
IdahoBoy View Drop Down
Direct Link To This Post Topic: Emptying Fresh Water Tank
    Posted: 16 Sep 2016 at 11:34am
When emptying my fresh water tank via the low point drain, the tank won't drain properly unless I turn on the water pump. Shouldn't gravity do the trick? Why do I need to have the pump on? What am I missing? Sorry if I'm just advertising my ignorance, I have it in surplus.
Direct Link To This Post Posted: 16 Sep 2016 at 11:52am
You don't drain the FW tank from the low point drain. You drain it with the drain on the bottom of the FW tank.
Direct Link To This Post Posted: 16 Sep 2016 at 12:52pm
Ha! I knew it had to be something very simple. Thanks and feel free to laugh at my ineptitude.
claytonc70 View Drop Down
Direct Link To This Post Posted: 16 Sep 2016 at 1:07pm
I actually can't get my low point end cap off...it seems like the whole line is going to tear off as I try to loosen the end cap.
Anyone else have this issue?  Do I have to get that end cap off?
2016 178 - unnamed shame
2012 Honda Pilot EX-L AWD
Direct Link To This Post Posted: 16 Sep 2016 at 1:24pm
I have seen people need pliers on them..
Gregm View Drop Down
Direct Link To This Post Posted: 16 Sep 2016 at 1:49pm
I also had to use pliers once. I sprayed the threads with a food grade machine lubricant afterwards and have not had that issue since
Gregm
2014 171
2015 Toyota Tacoma Prerunner
Direct Link To This Post Posted: 16 Sep 2016 at 1:51pm
Good tip!
NickLPod View Drop Down
Direct Link To This Post Posted: 16 Sep 2016 at 1:52pm
I got tired of getting sore (& dirty knees) undoing the black end cap to drain the FW tank.
So I added a brass 1/2 inch tap to the off-white threaded part.
I can now reach under the Pod to turn the handle 90 deg to drain .... & back when empty.
2016 R-Pod 180
2011 Audi Q5 3.2 V6
Wife Carole
Dog Corra
Direct Link To This Post Posted: 16 Sep 2016 at 2:56pm
That's really interesting, can you post a picture?
Direct Link To This Post Posted: 16 Sep 2016 at 9:25pm
I am sure I was told about the low point drain on my 177 when I purchased it in 2011.  HOWEVER for the first 3 years I forgot about them; they never were opened or taken off.  Finally in year 4 of ownership (2014) I was working on wheel bearings when I saw the sticker and went to investigate where they were.  Funny thing was I couldn't find either of them because someone at the factory totally covered them over with foam.  I cut thru the big glob of foam and found both low point drains.  Am amazed that I never got a leak with our cold winters in Northern Michigan.  Maybe using compressed air to blow out the water lines helped with this issue.
