| Author |
voisj
Topic: new R-pod owner 180 Posted: 20 Jul 2016 at 9:29pm |
Picking up my new 180 on Friday in Fresno (Toy Hauler liquidators) and heading straight up to the Sierras to dry camp for the weekend. Few questions for those in the know; 1) Bringing basic tools, is the Trailer metric or standard? 2) What size Socket for the stabilizing Jacks? I'm Bringing a cordless drill. 3) Are the fuses standard automotive? 4) I have a 40w solar panel can i just plug it in to the solar panel jack or do i need a controller? 5) I know it's nutty going straight up for 3 days dry camping from the dealer, what do i need to know about the R-Pod during the first time out? THanks! John
Jazz trumpet
Posted: 20 Jul 2016 at 9:35pm |
3/4 inch stabilizer Jack socket. You'll have an adventure for sure. You sound courageous. Enjoy
John and Marilyn
2016 Rpod 180
2001 Chevrolet Suburban
DaveC3
Posted: 21 Jul 2016 at 8:39am |
Get a set of square driver bits, all the small screws have the square type of head. Also get or bring a digital multi-meter, for checking battery voltages, charge state etc.
You may also but a set of mirror clips, the bathroom mirror is only held in place with double sided tape. We live in Texas and the heat made the tape fail and the mirror fell off.
I think you need a controller for the solar panel if you plan to charge the battery. Which brings up another option. The dealer put in a group 24 battery in our 180, it is at the bottom of the capacity. If you are going to boon-dock a lot you may want to upgrade your battery to two 12v batteries or two 6 volt golf cart batteries.
The fuses are like automotive fuses, our dealer said to buy a variety pack. but you may want to peek into the the fuse block to see what sizes the Pod realy has.
Get a torque wrench and make sure the lug nuts are tight (100 ft lbs). The lug nuts are 3/4 inch. I check them every trip.
One more thing to check before you start out, make sure the bolts on the brackets for you holding tanks are tight. Mine had a couple loose and there was a gap between the bracket and the frame.
We have enjoyed our 180, got it at the end of February and have over seven weeks of camping and eight thousand mile on it so far. It is too hot right now but we are planning another big trip this fall.
Good luck
Dave
2016 R-Pod 180
2015 Ford Explorer Limited
Leo B
Posted: 21 Jul 2016 at 8:45am |
Congrats on your 180! Enjoy your trip!
voisj
Posted: 21 Jul 2016 at 10:52am |
Dave,
Thanks for the tips!
square drive, who would have thought it?.
Had the dealer install an extra marine battery.
Ours came with mirror clips from the factory , must have heard the R- pod nation grumble.
I'll check the tanks bolts I assume a socket set should handle that. Anything else you can think of let me know!
Rgds
John
SLOPODMODS
John&Sue,SLO,CA
Posted: 21 Jul 2016 at 9:00pm |
This time of year, you will find that 1 battery will suffice. When we camp spring/fall and temps fall into the high 30's or lo 40's and the furnace gets a good workout we still will get 3 days minimum out of our 12 v deep cycle marine before switching over to the other one. We take it down until it shows 1/3 charge left. Those batteries are now going into year number 6. Also, DO NOT try to run your fridge on battery, it will drain it to zero overnight, make sure you are running propane to cool the fridge.
voisj
Posted: 21 Jul 2016 at 9:40pm |
Thanks for the fridge tip, is there a three way switch that you set to your preference or is it automatic? They wired my batteries together, and i planned to mount a marine style shutoff/1/2/both. never thought about just using one at a time. I'm pondering this one;) rgds John
SLOPODMODS
John&Sue,SLO,CA
Posted: 22 Jul 2016 at 5:05am |
You manually set it to propane, the icons on the left side show what mode you are in.
birderdiane526
Posted: 22 Jul 2016 at 10:06am |
Hi Dave! Great information! Thanks!
Hope all is well with you and Cheryl.
Diane and Michael
2007 Toyota Tundra
BLOG:Podding in Paradise,
birderdiane526.blogspot.com
voisj
Posted: 22 Jul 2016 at 12:01pm |
Thanks for the info! I'm sure I'll have more questions in 2 hours ,we are Hitting the road now to pick it up. And thankshanks to all gave me newby tips!! rgds John
SLOPODMODS
John&Sue,SLO,CA
