| Post Reply   |
| Author | |
| Leaton   Newbie   Joined: 19 Jun 2016 Online Status: Offline Posts: 5 |  Topic: Tongue jack clearance 179 Posted: 02 Jul 2016 at 5:25am |
| Is anyone else having clearance issues? My r-pod is in driveway and the design makes it impossible to put a board under the jack due to clearance and the fact that the boot lowers at an angle versus vertical.  oddly, I could fit a board before a trip and now can't, my driveway isn't perfect but wonder if the bolt has shifted affecting height.  In general though I am often kicking out dirt in parks....any insight  appreciated Newbie in NH | |
| this_is_nascar   Senior Member     Joined: 24 Jan 2010 Location: NJ Online Status: Offline Posts: 466 |  Posted: 02 Jul 2016 at 7:37am |
   Remove and don't use that yellow foot?
     "Ray & Connie"
 - 2017 R-Pod RP-180 - 2007 Toyota Tacoma TRD-Off Road | |
| johnmaci   Senior Member     Joined: 17 Jun 2014 Location: MD Online Status: Offline Posts: 202 |  Posted: 02 Jul 2016 at 7:47am |
   Maybe one of these instead: https://www.amazon.com/Fastway-88-00-6500-Flip-Automatic-Jack/dp/B003CE283I/ref=sr_1_10?ie=UTF8&qid=1467459990&sr=8-10&keywords=rv+jack+foot | |
| StephenH   podders Helping podders - pHp     Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6463 |  Posted: 02 Jul 2016 at 9:49am |
   Since it is a foot, don't use a board? That is the premise of the flip foot. You should not need a board under it. Your hitch height must be quite low for it to not work. My driveway is sloped, and I tow with a Ford Escape. I purchased the Husky Brute foot, but had to shorten it to make it work.  What was the load on your R-Pod and Tow Vehicle when it worked? What was the height of the hitch? Is there more weight now causing the height to be lower? That could explain why it worked before but won't work now. | |
 Happy is the man that findeth wisdom,... ouR escaPOD mods Former RPod 179 Current Cherokee Grey Wolf 24 JS | |
| osage   Senior Member   Joined: 13 Mar 2016 Online Status: Offline Posts: 146 |  Posted: 02 Jul 2016 at 1:01pm |
   to keep mine from dragging I removed the jack took the foot off and cut 2" off of the jack re installed the foot by drilling new holes in the shaft  now I carry a 2x6x 6 inch board when I need extra lift when we camp.
| Post Reply   |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
