adaviel
Topic: Problem with water pressure Posted: 30 Jul 2015 at 9:35pm |
I recently bought a 2011 Rpod 177, and am having some trouble with the water system. The previous owner had winterised it, and de-winterised it before delivering it.
I followed the directions in the manual to start the water system - fill the tank, open all the taps, start the pump - but I'm still not getting a good flow from the shower and the water seems aerated. The gauge shows the water tank as full, and indeed it was filled to the top the the point of overflowing from the filler. When the tank is full, the water to the shower is present but not an acceptable stream - it dribbles, basically. When the tank drops below about 3/4 full, the pump won't shut off by itself, and the shower won't work though there is some water from the sink tap. I'm nervous about operating the water heater in case it is not properly flooded.
I note that the water intake fitting on the water tank is halfway up one side, rather than underneath. I was wondering if there's an intake hose actually inside the tank that is out of position and is sucking air, and if so what to do about it. E.g. is there an inspection hatch somewhere for the tank.
Leo B
Posted: 30 Jul 2015 at 9:42pm |
Welcome to the group! Congrats on your 177!
CharlieM
Posted: 30 Jul 2015 at 9:54pm |
Check the winterizing valve. Near the pump there should be a valve connected to a short hose that goes nowhere. This is used to suck antifreeze into the pump during winterizing. If it was left open the pump will suck air.
adaviel
Posted: 30 Jul 2015 at 10:47pm |
I found that (behind a screwed-in panel; the documentation sucks...) Yes, I closed that. If I pull water from a bucket with that hose, it works properly, but from the tank I have aerated water.
I didn't hear any hissing as of air being sucked from the valve, thought it might have been masked by pump noise.
Right now the Rpod is at my daughter's place miles away so I can't try anything. Hopefully I can get it sorted out when I tow it home in a couple of months, though if there's something simple I could tell her what to do.
Tars Tarkas
Posted: 30 Jul 2015 at 11:11pm |
Just being sure: with the valve closed, you can't suck water from a bucket with that hose.
TT
FJ Cruiser
adaviel
Posted: 31 Jul 2015 at 2:43am |
On mine, it's a 2-way valve. Either the pump input is connected to the hose (the bucket), or to the tank. When I wrote "closed", I meant "connected to the tank".
Posted: 31 Jul 2015 at 8:19am |
Next thing to check is the debris filter right next to the pump. Unscrew the filter part and check for cracks.
Tars Tarkas
Posted: 31 Jul 2015 at 8:38am |
It sounded like you had it right, I just wasn't sure. In addition to Furpod's suggestion, is the hot water heater tank full? Try running the water with just the cold water valve at the sink open and then just the hot water. If your problem is just with the hot water, let it run in the sink until you have no more air, then in the shower, which will only take a few seconds after pure water at the sink. I'm grasping at straws... but it can take the hot water tank a good while to fill. Until then, it will be blowing air. TT
FJ Cruiser
adaviel
Posted: 31 Jul 2015 at 2:03pm |
Thanks for the suggestions, guys. I'm probably going to have to wait till I can tear the thing apart when I get it home.
I did find the debris filter, but that's upstream of the valve, so I'd assume I'd have a leak when pumping from a bucket, too. On the other hand, there's much less suction required for that so I might not have noticed.
The hot water tank, I'm pretty sure I did try most every combination - one tap open, both together etc. I should check the seal around the anode; that was changed and may not have had new PTFE tape. But the amount of air I'm getting seems much more than a small leak would account for.
I was quite surprised at the wide flat water tank arrangement - my old camper had a deep narrow tank impervious to tilt. I did level the trailer carefully after I saw that but it didn't help.
I'm still wondering what exactly is inside the tank. I didn't have the tools to take it apart - at least, I didn't have a hose clamp to replace the crimp-on one if I removed that, or any tape/sealant to re-fit fittings.
Wen
Posted: 31 Jul 2015 at 2:43pm |
I have a 2011 176, I had similar water pressure issue, then I found the extra hard water in my area built up solids inside the pipe and around the outlet of the tap, toilet got stuck too. You can do a test, unscrew the head tip of your kitchen tap and check inside(yes at the very end of the tap there is a little piece that can be unscrewed), if you see tons of white solids then that probably is the reason. My solution is mechanically clean up the build-up at where I can reach, use apple vinegar to cycle the water system a few times, things improved greatly in my 2011 R176.
