Post Reply
| Author | |
NMJohn
Joined: 28 Jun 2015 Location: Grand Rapids MI Online Status: Offline Posts: 35 |
Calendar Event: 30 amp line testerPosted: 15 Jul 2015 at 4:55pm |
A friend of mine uses some sort of "line tester" for the 30 amp outlet at campgrounds to check on the right voltage, polarity, etc. I've been looking online for such a device.
Any links to these on Amazon?
Is there any need for this? He also uses a surge protector and I've ordered one of them. Thanks, John |
JohnBG
Joined: 14 Apr 2015 Location: Deltona, FL Online Status: Offline Posts: 190 |
Posted: 15 Jul 2015 at 5:09pm |
Here's what I use: http://trci.net/products/surge-guard-rv/hardwires-portables/30a-portable-surge-protector I bought mine on Amazon for about $80. Here's the Amazon link: http://www.amazon.com/TRC-44260-Amp-Circuit-Analyzer/dp/B00JYMZ8HK/ref=sr_1_fkmr0_1?ie=UTF8&qid=1436994675&sr=8-1-fkmr0&keywords=rv+surge+guard+30A+surge+suppressor
You can spend more for a fancier one with an LCD readout or hard-wire version that you install in the camper if you want. I like this one. It's simple, just plug it in and it works.
Never experienced it myself, but some folks say pedestal power can be flaky at some campsites. I also like the surge suppressor here in Central Florida aka "Lightning Alley".
2010 R-Pod RP-171
2010 Honda Ridgeline TV |
NMJohn
Posted: 15 Jul 2015 at 6:30pm |
Thanks John BG.
I guess I was/am a little confused thinking that there was an inexpensive plug-in device that would check the amps, volts and polarity without the surge protection option. I have a surge protector, but was looking for just a meter to tell me if it was safe to plug in the rpod with surge protector I have. Maybe they don't make such a thing and I'll just rely on plugging in the surge protector I own and hoping for the best. But if you knew ahead of time that the circuit was good, it would be handy. But thanks for your response! John
JohnBG
Posted: 15 Jul 2015 at 6:37pm |
There might be a stand-alone analyzer, but all the ones I have seen come with the surge suppressor like the one I bought.
2010 R-Pod RP-171
Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9066 |
Posted: 15 Jul 2015 at 10:32pm |
See the link in my signature, the first link that comes up on that page. I talk about using 2 inexpensive testers to check for correct wiring and to be sure your camper frame isn't live. If you want to check for voltage too, you'll need a cheap voltmeter.
Pod People
Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1098 |
Posted: 16 Jul 2015 at 1:59pm |
This is an electrical tester that I put together
from directions on some RV forum--maybe this one, but I can't remember where it
came from.
It is simply a 30 amp male plug mounted to a pvc receptacle box with the standard receptacle inside. Plugged into the receptacle is a standard receptacle tester which shows polarity, grounding and hot/ground or hot/neutral reversed. the second (white) item is a voltage indicator . I'm sure there are probably more sophisticated instruments available, but I made this one for about $30. Vann |
NMJohn
Posted: 16 Jul 2015 at 2:40pm |
You're very ingenious and electrically talented than I am. I've already ordered a kit on Amazon that another member uses (and explained with a YouTube video). But thanks for showing us your work!
John
Post Reply
