  New Posts New Posts RSS Feed: Brake Light Issue R179
Topic ClosedBrake Light Issue R179
Codex1554 View Drop Down
Direct Link To This Post Topic: Brake Light Issue R179
    Posted: 30 Jun 2015 at 4:46pm
Greetings All,
We picked up our new 179 in mid-May and recently noticed the passenger side brake light isn't fully working.
Rpod Tail Light
This is occurring when headlights are on and also when brake are applied.  The photo shows with the latter.
My question:  is this wiring related or am I looking at aunit replacement?  I'd rather do it myself if I can but if a warranty call to the dealer is in order I'll go that direction.
Thanks for any feedback!
Jim
Jim McP
Beaverton OR
RPod 180 (Podamus)
Nissan Xterra
Direct Link To This Post Posted: 30 Jun 2015 at 5:29pm
It needs replaced. They are all LED. It's a problem with the board.
Direct Link To This Post Posted: 30 Jun 2015 at 9:14pm
Welcome.
Direct Link To This Post Posted: 30 Jun 2015 at 9:45pm
Welcome to the group!
jtkg171 View Drop Down
Direct Link To This Post Posted: 31 Jul 2018 at 6:42pm
if your still around on this site, could use some insight... Got a problem with my rear right led rpod 171
running lights work fine. but brake and signal very very faint.. so strange. all the wiring seems fine, and it even works perfect once in a while.. i think it may be the light itself.. i even jumped it to 12v and ground.. got bright and worked but always on... what do you think.. its just over 1.5 years old 2017 171
John and Kathy
2017 R-Pod 171 Hood River
2000w Inverter + 130W solar
2017 Grand Cherokee Trailhawk 5.7L
GlueGuy View Drop Down
Direct Link To This Post Posted: 31 Jul 2018 at 8:21pm
Probably a loose or corroded connection. High resistance can cause this kind of problem. Since it is only the right side, it's probably either right at the light, or where the right & left are connected together near the front.
ZuBrew View Drop Down
Direct Link To This Post Posted: 31 Jul 2018 at 9:02pm
I've seen some solder joints on these types of boards break.  Sometimes you can find them by powering the light and tapping on the solder joints. Then just re-solder them.
2017 Chevy Silverado 1500 4X4
2018 R-Pod 189
2013 Yamaha FJR 1300A
Direct Link To This Post Posted: 31 Jul 2018 at 9:15pm
took another look dont see anything loose or corroded.. Do you know which wires it might be the grounds look good too..
John and Kathy
crankster78 View Drop Down
Direct Link To This Post Posted: 01 Aug 2018 at 4:54am
Greetings
I had the same problem and found a gob of mastic stuck to the back of the light causing the board to overheat and fail.  You need to order new tail lights and use good quality silicon to seal around them.
Crankster78
Crankster 78 R-179 2015
craigwood View Drop Down
Direct Link To This Post Posted: 01 Aug 2018 at 6:44am
Had a similar intermittent problem with my 2015 179 - right LED taillight.  My TV ('17 F150) kept telling me I had a bad taillight on the trailer but it was intermittent so it took me awhile to actually 'see' the problem when hooked up.  Removed it and wired it to a spare battery and after some time it confirmed the taillight itself was bad.  An easy replacement for about $40.
