| Author |
jarpod
Topic: air conditioner Posted: 19 May 2014 at 8:12pm |
just bought a 2010 175 and was wanting to know how to tell if the ac is a 11500 btu or the 13500. have not taken any covers off to look for the model number. i have ran the ac ,microwave and the tv all at the same time on a 20amp breaker and all worked fine if that helps or matters.
thanks
Posted: 19 May 2014 at 10:07pm |
Hard to say, probably the best way is to take the cover off on the inside, then search the model number, sorry.
jarpod
Posted: 20 May 2014 at 1:07pm |
that is what i figured i would have to do but was being lazy thought maybe there was another way to tell , the manual has all of the model # listed
thanks
Sleepless
Posted: 20 May 2014 at 1:14pm |
My 178 came from the factory with a sheet that listed all the major components and appliances including the model and serial numbers. You might want to check all of your literature packages to see if your pod came with such a sheet.
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
jarpod
Posted: 20 May 2014 at 3:53pm |
sleepless
i went and double checked all of the paper work that came with the 175 (it is a used unit) . i ended up finding 2 different manuals both have different model # listed on the ac . so i will have to pull the cover and find the model #
thanks
marwayne
Posted: 20 May 2014 at 4:34pm |
I was always telling people my AC was 11500 BTU, took of the inside shroud, low and behold it said 13500 on the sticker.
jarpod
Posted: 20 May 2014 at 6:24pm |
marwayne
just went and took my inside shroud off and it is a 11000 btu which was what i was hoping for. i can get by with the honda 2000 generator by what i have read here on the forum , i have a regular 2500 homelite but it is loud.
thanks
