  New Posts New Posts RSS Feed: Laundry List of needs for 1st purchase
Topic ClosedLaundry List of needs for 1st purchase
Mscmndv View Drop Down
Direct Link To This Post Topic: Laundry List of needs for 1st purchase
    Posted: 08 Mar 2014 at 1:29pm
My wife and I are looking at purchasing our first ever TT this next winter so we are in the planning stages of what do we need to buy, outfit, adjust, etc...to have a successful launch into TT camping. I drive an 05 Nissan Xterra, it does have a class II hitch with 7 pin electrical but no tow package.
So as total newbies, in addition to the basic R-pod (thinking the 179) what do we need to think about buying and/or doing?
I have done some searches on the forum but didn't find a thread for a composite list of needs/to dos.
Thanks!
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 08 Mar 2014 at 2:10pm
You will want to upgrade to a class 3 hitch, make sure you have a transmission cooler if it is an automatic transmission, and get a controller for the trailer brakes.  I think you may want to get a distribution hitch as well with a light and short TV like yours.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 08 Mar 2014 at 2:13pm
We really like and use our r-dome! It adds a lot of extra room to pod-camping!
Boomertype View Drop Down
Direct Link To This Post Posted: 08 Mar 2014 at 2:48pm
You will need things like a hose to hook up to city water and to fill your water tank.  A water pressure regulator is a good idea to add to your list.  Some water supplies are too high - the RV park in my wife's home town is a 100 psi, shouldn't be higher than 60.
Leveling blocks, for side to side leveling.  Used below a tire on the side that needs leveling. Also a carpenters level to determine when you are level.
Pads for the stabilizer jacks.
That's a good start.  I know there are more. . .
Direct Link To This Post Posted: 08 Mar 2014 at 3:43pm
   You will need time to go camping and patience when things do not go as planned. LOL
2014 Ram 1500 Quad cab
P&M View Drop Down
Direct Link To This Post Posted: 09 Mar 2014 at 6:32pm
If you have not done much in the way of camping, make sure you know what kind of camping you are going to want to do and that you will be comfortable doing. If you do not buy a camper that fits your style and needs, you are not going to be happy with it or the experience at all.
Going camping means many different things to many different people ... just know what it means to you and then find a camper to match.
P & M ... and Comet too!
2012 171 -- The Monkey Pod
2018 Ram 2500
wingnut2312 View Drop Down
Direct Link To This Post Posted: 10 Mar 2014 at 9:56am
We were there with you last year! This forum has a ton of great advice. It also has a lot of OOPS remarks to keep you from making the same mistakes twice. Make sure you take the time to look through everything.
That being said, definitely follow the prior advice of upgrading to class 3, and a trans cooler. Make sure you can tow the weight. Full load of water and gear is not in the weight specs.
A BAL leveler works great and is easiest to use for the price. Flashlights, multi-tool and a folding shovel. The r-dome is awesome, but offers zero protection from the sun! It offers a little shade on its own, but it will become sauna-ish. Still, it's very nice to have and will keep bugs out.
There isn't soap dish for the shower. Command Strips has one for like $5. Check the campground amp usage. You may need a 30 amp to 50 amp extension cord. We also bought an external surge protector. Probably upgrading to an internal hardwired evebntually. Battery has to be disconnected when not in use unless you use a trickle charger. We don't so I bought a disconnect switch so I wouldn't have to keep disconnecting the wires. Made the mistake of connecting them wrong and blew fuses!
KYMooses posted a video for winterizing the pod. Bookmark it and you'lll be doing it in 15min.
Mistakes to avoid!!!! 1. Don't connect the battery wires wrong. 2. When lowering the tongue jack, make sure the truck is not still attached.... 3. Don't forget toilet paper. 4. Drive around for a bit to get used to parking and backing in. 5. If water backs up in the shower, it's time to empty the holding tank. Not just keep showering
Outside of that, have a good first aid kit. Don't skimp here. Shouldn't be more that $40. REI backpacker kit is good. The furnace fan is loud so maybe buy an electric heater (portable).
Have fun!
2014 rpod 182G
Ford Expedition
LePodders View Drop Down
Direct Link To This Post Posted: 10 Mar 2014 at 11:38am
magnetic level
chocks
jack pads
outdoor carpet
door rug
oxygenics shower head!
folding shovel
outdoor camping trashcan
nice sewer hose
hose splitter for camp water faucet
Poddy by Nature
cody91 View Drop Down
Direct Link To This Post Posted: 10 Mar 2014 at 12:19pm
Have fun!
Why does the battery have to be disconnected when not in use?  Isn't it possible to just connect the Rpod to a home electrical outlet every 30 days or so to charge the battery?
Direct Link To This Post Posted: 10 Mar 2014 at 12:30pm
Most people don't or can't hook up at home, many are in storage lots, etc.
If you have the option to hook up, then you don't need to disconnect the battery. Actually if you have the ability, just hook it up and leave it. Won't hurt a thing.
