  New Posts New Posts RSS Feed: Lukewarm Shower
Topic ClosedLukewarm Shower
Camper Bob View Drop Down
Direct Link To This Post Topic: Lukewarm Shower
    Posted: 21 May 2013 at 11:32am
While camping I foolishly did not check our propane, and this morning we had a very lukewarm shower with only the electric heating element to heat the water. Fortunately, propane is available locally.  Evidently the lukewarm water is just that, and I was wondering how long the hot water takes to recover with only the electric element to heat it.  I have added checking the propane before every trip.  Brrrr.  Safe Travels.
Camper Bob and Camper Sue
2013 Rpod 171HRE(ORPod)
2016 Lance 1685
2015 Nissan Pathfinder
Goose View Drop Down
Direct Link To This Post Posted: 21 May 2013 at 2:44pm
Can't say that we have ever used the water heater on propane other than to bleed the air from the line. We have always used the water heater on electric and I turn it on at the breaker when breakfast is being cooked up and by the time we are done eating the water is VERY hot. It really does not take that long. Goose
Cooks128 View Drop Down
Direct Link To This Post Posted: 21 May 2013 at 4:01pm
took 30 minutes at most to produce water hot enough for a shower over the weekend.
2013 182G
TV 2004 Dodge Dakota V8 - 2012 Jeep Unlimited Rubicon
Direct Link To This Post Posted: 21 May 2013 at 4:02pm
Are you sure your bypass valves are set correctly?  Every time someone mentions lukewarm water, or a burst of hot then back to cold, the valves aren't set right.
Recovery time is only a little longer on electric vs. propane and neither takes that long as Goose said.  If you use both modes you get a very fast recovery time, useful for multiple people that need a shower right after the other.
The thermostat temps aren't much different between the modes, not enough that you can feel the difference - in other words, both are hot.  The electric mode is set a little lower to maintain the temperature so if you have both on you'll only use propane when you are actually using hot water.
Direct Link To This Post Posted: 21 May 2013 at 7:55pm
Valves are in proper position as we have had hot water with propane.  Seems to me, that possibly our electric element has failed for whatever reason.  I have refilled the propane bottles and after lighting the stove the water heater fired right up.  I have now turned off the switch under the sink to see if the electric element is working.  Stay tuned.  Thanks for the help.  Safe Travels.
2016 Lance 1685
Direct Link To This Post Posted: 21 May 2013 at 10:30pm
"recovery time" for our water heater is 60 minutes. So from cold to hot shower is just that. We use electric if available, never a problem running out of hot water, or a problem with it being only warm.
