Post Reply
| Author | |
Hugozork
Joined: 02 Jun 2011 Location: Laval, Canada Online Status: Offline Posts: 73 |
Topic: prodigy p2Posted: 04 Jul 2011 at 1:03pm |
Hi
when i bought my rpod, the vendor sell me a P2 brake controler. the technicien said that there is no setup with the P2 controler. Is it true. |
FrenchyPOD 171 2011
Toyota FJ Cruiser 2008 - MIA |
kymooses
Joined: 01 Aug 2010 Location: Louisville, Ky Online Status: Offline Posts: 1807 |
Posted: 04 Jul 2011 at 3:26pm |
We use the Prodigy P2 controller on our tow vehicle with our Rpod. Our dealer hooked it up just fine.
Outbound
Joined: 19 Nov 2009 Location: Oshawa, Ontario Online Status: Offline Posts: 767 |
Posted: 04 Jul 2011 at 4:09pm |
Yes, there is a setup procedure to adjust the amount of power (and when the power is applied) to the brakes. You should familiarize yourself with the procedure as you will have to adjust your brakes on occasion. You can find a manual (here).
Hugozork
Posted: 04 Jul 2011 at 4:22pm |
thanks for your help. the technician said to me he prefer the voyager controler, i understand now why he doesn't adjust it.
FrenchyPOD 171 2011
Outbound
Posted: 04 Jul 2011 at 5:35pm |
Although the Voyager is fine, you'll be much happier with the P2. The adjustment procedure is fairly simple and you'll likely only have to do it once or twice a year.
Hugozork
Posted: 12 Jul 2011 at 10:24pm |
last week-end i try to setup my P2 controler so before change the setting to 6.0 according to the owner manual, i apply manual brake and i read 10 ! i drove at slow speed an apply manual brake and even with the 10 settings the wheel doesn't lock, is-it normal ?
FrenchyPOD 171 2011
Damour
Joined: 07 Jul 2011 Location: Quebec Online Status: Offline Posts: 162 |
Posted: 12 Jul 2011 at 10:27pm |
Some problems with the break control ?
Installed at Lussier ?
(If so , give me some details in french on PM , they install our break control tomorrow at Lussier..)
Hugozork
Posted: 12 Jul 2011 at 11:06pm |
Check your inbox
FrenchyPOD 171 2011
Post Reply
