  New Posts New Posts RSS Feed: 2019RPOD 191
2019RPOD 191
D.PHILLIPS View Drop Down
Post Options Post Options   Quote D.PHILLIPS Quote  Post ReplyReply Direct Link To This Post Topic: 2019RPOD 191
    Posted: 14 Nov 2025 at 10:04am
What size (Width) Vinal trim do I need for my 191 RPOD. Noticed it was cracking on the front and need to replace.
Doug Phillips
Post Options Post Options   Quote D.PHILLIPS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2025 at 11:25am
Going with 1"
Doug Phillips
JR View Drop Down
Post Options Post Options   Quote JR Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2025 at 3:14pm
That's what I used and it seemed to work just fine. Have fun doing it.
Jay
179/2019
Post Options Post Options   Quote D.PHILLIPS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2025 at 6:00pm
Thanks
Doug Phillips
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 5:38pm
Replacing will be much easier if the temp is 60 or above and with the sun beating down on you.  If it is cold and cloudy, the job will be much more laborious.  At least keep it warm inside before going out in the cold to perform this task.  If in the cold, maybe keep the roll inside your jacket where you can keep the product warm and more pliable.
