Parts Catalogue/Webath Liner |
Post Reply
| Author | |
jshectman
Joined: 10 Nov 2025 Location: NC Online Status: Offline Posts: 6 |
Post Options
Quote Reply
Topic: Parts Catalogue/Webath LinerPosted: 10 Nov 2025 at 3:24pm |
2018 Rpod RP-171 new to me. :) The previous owner seems to have cut the wetbath liner (I presume to access water lines or similar). I'd really like to replace it but I can't seem to find an online parts dealer or catalogue. I'm reasonably handy and think I could complete the job - just need to buy the parts. Any ideas? Many thanks!
Edited by jshectman - 10 Nov 2025 at 3:25pm |
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3443 |
Post Options
Quote Reply
Posted: 16 Nov 2025 at 5:17pm |
Are you referring to the shower pan itself, or the pan including the surrounds or what? Am not exactly clear as to what you mean by 'wetbath liner.' I do have an RV Parts and Accessories catalogue which includes a whole page of shower pans and pans including the surrounds. Please let me know exactly what you need and the dimensions, I will check this catalogue to see if it has what you are looking for. |
jshectman
Post Options
Quote Reply
Posted: 17 Nov 2025 at 12:03pm |
Thank you - it's two of the "walls" that make up the wetbath liner. I'd like to replaces them both. Here is a picture enclosed.
Post Options
Quote Reply
Posted: 17 Nov 2025 at 8:23pm |
There are two possibilities listed in this catalogue. 1st is 2 sided with measurements of 34" x 36" x 67." The 2nd is 3 sided with measurements of either 24" x 32" x 66" or 24" x 36" x 66." If either of these are a maybe I can forward the item# to you. OR, maybe you can purchase the same material at Lowes or Home Depot locally?
MoPod
Joined: 10 Oct 2013 Location: Pittsville, MO Online Status: Offline Posts: 109 |
Post Options
Quote Reply
Posted: 19 Nov 2025 at 10:35pm |
I believe what you are seeing in this bathroom is where the sink was removed, leaving the two spots shown in your picture. When I removed the sink, I bought a single 4x8 sheet of embossed white fiberglass reinforced plastic that I cut to fit the area below the faucets and then wrapped it on the back wall at the same height. I removed the two pieces of corner molding, secured the panels with liquid nails, then retrimmed the top of the panels and the corners with matching trim that I purchased in the same area of the big box store. It's lasted 10 years so far. Cutting the sheet it the most difficult part of the job. I got my stuff at Lowe's, but I've seen the same products at other home improvement stores.
Edited by MoPod - 19 Nov 2025 at 10:49pm |
Bill & Nancy
2015 RPod 179 Previously 2010 RPod 176 2014 Explorer Sport |
Post Reply
